- funinthesun95
New to me shocks are starting to take shape.
- IMG_4673.JPG (17.32 KiB) Viewed 2293 times
- IMG_4672.JPG (23.25 KiB) Viewed 2293 times
- IMG_4671.JPG (23.56 KiB) Viewed 2293 times
- IMG_4670.JPG (38.48 KiB) Viewed 2293 times
Nice !!!!funinthesun95 wrote:Thank you Juanco for going through the herbst/Baldwin C6. Just making sure she did not need any love from sitting for a little while.
Sent from a remote Baja location
- funinthesun95
Time to pick and choose my priorities.
Big Shocks ....yes
2 A/c units ....yes
big tires.... yes
Room for all this .....nope, but I still love the bronco.
Big Shocks ....yes
2 A/c units ....yes
big tires.... yes
- funinthesun95
she is sitting on Fox coilover now. ..........Bypass shock are up next
Mock up tranny coolers are done.........radiator and AC are next mock up
- unnamed (1).jpg (10.82 KiB) Viewed 2040 times
- unnamed.jpg (11.83 KiB) Viewed 2040 times
- funinthesun95
We are back at it..... Steering Ram, pump, lines, and res going in this week
I need that T/C mount bracket from Howe Part number #920...look it up super cool option
Solo does a mod as well I will look into
Learn something new everyday. Thanks Willie. Howe has a great PDF of how(e) the bracket installs and what everything looks like and what needs to be cut. Very cool info. I will add that little part to the sh*t I need to buy list.
- funinthesun95
damon1272 wrote:Learn something new everyday. Thanks Willie. Howe has a great PDF of how(e) the bracket installs and what everything looks like and what needs to be cut. Very cool info. I will add that little part to the sh*t I need to buy list.
Yes it is nice way to move to the T/C pump if you don't have a Sag set up .....90% of us the Sag is fine, but they are harder and harder to fine.
Solo does a alum mod that is nice, as well if people don't want to fab it them self.
Links below
http://howeperformance.com/wp-content/t ... df/920.pdf
http://www.howeperformance.com/parts/pump-brackets/
Most of us will use a #315 pulley . The pulley should be as close to 1/1 ration to crank as possible and this pulley is only rated for 6000 rpm witch is fine for the 351w and our power band.
- funinthesun95
if you plan on race style driving always around max RPM yes.
My motor set up and the ram assist, along with large tires, I want the pump moving fluid at lower RPM's to accommodate.
The 6000 rpm mark is burn up pump mark! and has to be a constant is how I understand it. but it could happen to me we will see. The next option is a 6.5 pulley and I am not sure I will be on the gas enough to have it work the way I want it to at slower speeds.
I have the same set up on mine. The only problem I have with the set up is in the tight technical stuff you have to be on the gas or the pump will not keep up. I will be switching to big box and T pump soon if I keep my bronco.
- funinthesun95
Copy
- funinthesun95
If anyone is coming to the Mint....Friday I will be posted up at the @1niceride trailer with the Truggy on Fremont street
Come say what's up.
Willie
Come say what's up.
Willie
- funinthesun95
working on steering 25 bucks and i have a T-C pump hah
- c69442d3a2d38f4b4835a11c5c571de2.jpg (387.34 KiB) Viewed 1476 times
- IMG_9472 (1).JPG (249.91 KiB) Viewed 1476 times
- funinthesun95
with the steering we are finishing Core Support stuff
New wheels and tires next.
The glass will be cut to clear them.
I have rear glass being made to match Autofab front finders and fit 37 to 39 inch tires and wide rearend. I would have just ran Brandon rear glass but I thought keeping the autofab front glass was a good idea.
it was not totally the correct move.... autofab glass has to be trimmed pretty good to clear. This I had already planned on but will I like it??? I maybe going to Brandon glass if I don't like the trimmed autofab front finder.
The rear glass I partnered up with my buddy Tank as he needed some as well. So they will be called Tank finders....hah
Tank has done a ton of work getting them ready and he is one of the nicest humans, I have met in off road. side note my 2 year-old nickname is Tank as well... hah so 3 great reasons for the name.
They should turn out nice. I hope to have them in the next few weeks.
- IMG_9467.PNG (71.33 KiB) Viewed 1472 times
- funinthesun95
well the Rear Bypass fit....
- IMG_0479 (1).JPG (30.35 KiB) Viewed 1365 times
- IMG_0481 (1).JPG (24.34 KiB) Viewed 1365 times
- funinthesun95
changing a few things
- methods 2.jpg (9.36 KiB) Viewed 1242 times
- method 1.jpg (9.57 KiB) Viewed 1242 times
Are those 39's?
- funinthesun95
yes they are yikes.
Sweet - they can hit both your firewall & bumper at the same time! lol.
