Cactus Cooler
Post by Cactus Cooler »
LIKE BUTTON! looks good stretched!
have not seen that one before - it looks sweet!
It will be interesting to see how he does the shell. I would like to see it with stock size windows with the shell stretched and the windows centered in the shell.
Nice build...
David...
nubreed71
Post by nubreed71 »
So jealous of those BTR wheels...
That is awesome!
drewbee88
Post by drewbee88 »
So I picked up a new ride today, not sure what I will be doing to this. Couldn't pass up such a clean and well documented supercab. A crew cab would of been nice but I didn't have the money and have not seen a nice enough one around. ImageImageImageImage
Cactus Cooler
Saweeet, 76? 460? be a cool prerunner
It's like a time capsule
You can paint it in a super heavy flake the same color brown with some sweet ass stripes along the sides. Shagg ceiling and you're done!
drewbee88
Post by drewbee88 »
Cactus Cooler wrote:Saweeet, 76? 460? be a cool prerunner
77 460, 47,000 miles. Thing drives like a new pickup. Drove it over 250 miles home after buying it... It is taking a lot of restraint to not start Turning it into a Prerunner. I will be bending the beams and leveling it out and putting some 35s on it to start. If I can get the 35s to fit.
Sent from my Nexus 6P using Tapatalk
cwrisley
Post by cwrisley »
That's a really clean pickup. I love those dent sides.
My buddy has a lift for it I think....I will ask
35's will fit with glass and a leveling coil, but you'll most likely get into the front fender with them on a 2" or so lift. Rear is easy - 35's pretty much can go on at stock suspension/ride height.
drewbee88
Post by drewbee88 »
ChaseTruck754 wrote:35's will fit with glass and a leveling coil, but you'll most likely get into the front fender with them on a 2" or so lift. Rear is easy - 35's pretty much can go on at stock suspension/ride height.
Thank you for this, I've been doing some research on suspension, and am looking at bending beams and throwing a new coil in there. Only think I'm trying to find out is the rear steer with the lift. My thoughts were to run a 3" coil, extend radius arms and run a heim. I want a simple clean setup. Maybe some autofab fenders. Trying not to go overkill and keep it simple and usable.
I know you just said simple but..... Giant did a TTB conversion on one.
That setup will work well and the rear steer will be just fine with it!
If you want to be all fancy pants about it - get a 5-6" coil & build taller coil buckets so they only net a 3" gain in ride height. Some of the deaver 5.5" coils for the TTB broncos may work well for this.
Put the coils on the truck, run a set of old tires & go for a lap or 2 around the neighborhood. Back the thing up, bounce it over speed bumps, etc. Do whatever you can to get the coils to seat & settle a little & THEN bend the beams. Do it on the truck with an angle finder on the rotor face. Take the beams off & plate um. Simple & strong.
drewbee88
Post by drewbee88 »
I am currently shopping around for coils, I found some procomp coils for a ttb bronco, 4" lift over stock, trying no to do a modified bucket if I don't have to. Going to look it over good this evening. I have a set of 12" bypasses to throw on the front right now.
Note there are 2 different coil buckets on these trucks and the top wind on both of them is a bit different than the TTB bronco stuff.
Here is coil bucket type 1 = lighter duty trucks. It's a bit shorter than the next one.
9-23-09 F100 susp off.jpg (93.78 KiB) Viewed 1184 times
This is coil bucket type 2 - found on more heavy duty or higher GVW trucks. It's taller than the 1st one shown above
x 294.jpg (89.8 KiB) Viewed 1184 times
76 frame section.jpg (82.99 KiB) Viewed 1184 times
drewbee88
Post by drewbee88 »
Awesome, I am taking some measurements and looking around, I may just build a coil bucket if its not to hard for the ttb coils as they are much easier to find/source... I also though about using some 4wd bronco springs but I would have to build a spring retainer doe the beam. Definitely looking to go about 4" higher.
