Andy (eoffroader's) 94 build
eoffroader
Well its finally time I started a build
After abusing my 88 for a while I decided to build my 94 which is nicer and cleaner. So the plan is 4.5 over beams that I'm having done at Trac performance 2.5 x14 coil overs heimed radius arms deavers and shock tower and a cage some day. I bout this bronco for 1000 with a burnt valve so first things first and trade the bumper before fixing the motor haha thanks motorbreath. Now to get to work more pics later as the build goes on.
- 20160215_093801-480x853.jpg (79.93 KiB) Viewed 3742 times
eoffroader
Re: Andy (eoffroader's) 94 build
No pics but just picked up a pair of beams to have dropped of for some work one step closer
eoffroader
Yes I am cwrisley what part of El Cajon do you live in
eoffroader
Getting a little closers been real busy and haven't had time for the bronco but it's finally under way
- 20161203_125331.jpg (868.19 KiB) Viewed 3291 times
eoffroader
- zachwabbit
eoffroader
Thanks Zack it's finally getting there
eoffroader
Some more updates
eoffroader
eoffroader
eoffroader
I spy a Bilstein coilover!
eoffroader
Yes you do a 14 inch short body
Coming together man !! Looks good
eoffroader
Thanks man its some long nights but hoping new years is the maiden trip
IV95BRONCO
- Bronco Info: got a 1995 bronco with a leveling kit up front running 33s on alcoas! my 3rd bronco
looking great
eoffroader
just about done on the front end just need breaks and limit straps then onto the rear
eoffroader
got the front end sitting on its own weight but still have some buttoning up to do
