SteveG's 84-SOLD!
Re: Steve's 84
Ya know, with those fuel lines, I could throw in a complete engine harness.........
Re: Steve's 84
Well then I think I'm gonna take you up on that!BDKW1 wrote:Ya know, with those fuel lines, I could throw in a complete engine harness.........
- BajaF250
- Bronco Info: 1982 Ford F250
Re: Steve's 84
What do you think the drawbacks are to that setup? Obviously one would be space under the hood, but if you have the space for the extra "stuff," It sounds like that's the way to go. Have you ever had to change an in tank fuel pump out on the trail? It is quite the challenge. Accessability is a good thing!SteveG wrote:Whatever I choose, it will definitely use stock parts. While the accumulator would be a custom piece, the pump housed inside would be a stock Bronco/F150 pump which I could find anywhere. I'm all about stock parts....BajaF250 wrote:I decided to cannibalize all the fuel lines from a donor truck up at 67 (wrecking yard) and then lay it all out in the truck. I used all the original Ford fittings and it made it much easier when connecting to the fuel tank (in tank pump, stock) and the fuel manifold (again, stock). The reason I went that way is was to maintain as close to a stock configuration as possible. If, in case, I every needed parts, especially in BC, I could have some reasonable confidence I could get them. It made for an easy installation and it runs great!
The really cool part about the accumulator is it would take less than 5 minutes to have the pump out in the event of a failure. It also makes any sort of testing super easy since most of the fuel delivery system is under the hood.
Re: Steve's 84
There's not really any drawbacks other than the initial custom build. It wouldn't take up much space. The accumulators a friend of mine builds for his EFI systems is about half the size of the average car battery.
Re: Steve's 84
Tom, I put in a request for a price for the fuel accumulator. I don't know when I'll hear back on it but I'll let you know. I took a closer look at a couple my buddy had in the shop an man are they cool. One he was installing in an early model Mustang uses the stock mechanical pump to supply the accumulator and a carburetor needle, seat and float to maintain the fuel level in the accumulator. This particular fuel delivery system will use the stock single fuel line from the tank to the pump, a line from the tank to the accumulator and a single high-pressure line to the fuel rail... super simple, super clean and VERY serviceable.
The ECM and all relays are housed in a similarly sized box next to the accumulator. EVERYTHING EFI related is under the hood and easy to get to. I love it.
Re: Steve's 84
Can you post the cost of the accumulators? If not - PM me as I may be interested as well. I was possibly looking at trying to find a stock one off something and scab it on, but I hadn't looked too far into it yet.
Re: Steve's 84
I'll let you know, Steve. He's also considering having it certified so he can sell them with E.O. numbers (smog legal)... That would be super cool as it is a (perceived) gray area for smog referees and there's a good chance I'll get grief over it when trying to get this thing approved.
Re: Steve's 84
Not an issue for me
but good for those like you that still choose to deal with refs, etc.
Re: Steve's 84
Trust me. I don't want to visit the referee. And I'm still not 100% committed to it for that sole reason. If there was a smog exempt frame that the Bronco cab would fit on I would do a cab and suspension swap....
Re: Steve's 84
If there were a "bigger" bronco that was smog exempt - I'd probably own one. Or I'd do similar to what you said. Heck - I've considered a stretched bronco body on a 70's F series short bed frame. I'm just too lazySteveG wrote:Trust me. I don't want to visit the referee. And I'm still not 100% committed to it for that sole reason. If there was a smog exempt frame that the Bronco cab would fit on I would do a cab and suspension swap....
Re: Steve's 84
There is, it has AZ numbers.SteveG wrote:Trust me. I don't want to visit the referee. And I'm still not 100% committed to it for that sole reason. If there was a smog exempt frame that the Bronco cab would fit on I would do a cab and suspension swap....
- Silverslk
Re: Steve's 84
HAHAHAHA. Good call Philo. I have AZ plates on my commuter but hate worrying about getting hassled. I'll be smogging my car again and getting CA plates real soon.
- BajaF250
Re: Steve's 84
I'd really like to see the accumulator as well!ChaseTruck754 wrote:Can you post the cost of the accumulators?
- BajaF250
Re: Steve's 84
It's a drag that your BAR smog guy is so unreasonable. The guy down here gave me no grief at all. As a matter of fact, the guy that was actually doing the inspection was a monkey and gave me some grief over the EGR, stock headers and GT-40 intake manifold and the CA BAR guy shut him down and told him it was all good. Overall it was pretty quick, in and out.SteveG wrote:Trust me. I don't want to visit the referee. And I'm still not 100% committed to it for that sole reason. If there was a smog exempt frame that the Bronco cab would fit on I would do a cab and suspension swap....
- BajaF250
Re: Steve's 84
Steve,SteveG wrote:Tom, I put in a request for a price for the fuel accumulator. I don't know when I'll hear back on it but I'll let you know. I took a closer look at a couple my buddy had in the shop an man are they cool. One he was installing in an early model Mustang uses the stock mechanical pump to supply the accumulator and a carburetor needle, seat and float to maintain the fuel level in the accumulator. This particular fuel delivery system will use the stock single fuel line from the tank to the pump, a line from the tank to the accumulator and a single high-pressure line to the fuel rail... super simple, super clean and VERY serviceable.
This sounds like a great setup... can't wait to see it all when you post some pics! What computer will you use?
Re: Steve's 84
Same here on all accounts!ChaseTruck754 wrote:If there were a "bigger" bronco that was smog exempt - I'd probably own one. Or I'd do similar to what you said. Heck - I've considered a stretched bronco body on a 70's F series short bed frame. I'm just too lazy
Yeah, as I said before, not looking forward to it. I might end up taking it to a different ref out of the area.BajaF250 wrote:It's a drag that your BAR smog guy is so unreasonable. The guy down here gave me no grief at all. As a matter of fact, the guy that was actually doing the inspection was a monkey and gave me some grief over the EGR, stock headers and GT-40 intake manifold and the CA BAR guy shut him down and told him it was all good. Overall it was pretty quick, in and out.
The accumulators really simplify things. I really liked the set-up on the Mustang he was working on. That car also has a similarly sized aluminum box next to the accumulator. Pull the lid (one-piece, sides and top) and it reveals the ECM and relays. Exiting the box are the EFI loom, a wire to the positive battery terminal, a ground wire and a hot wire to feed the fuel pump next door... super clean, super simple.BajaF250 wrote:Steve,
Re: Steve's 84
I've done about 95% of the wiring work that can be done outside of the truck. I'm still trying to decide what to do about fuel delivery. I should just put the pump in the tank as that would be cheapest and this is a super low buck project, but I just don't want the pump back there... we'll see.
Once you strip down the EFI harness to it's bare essentials and weed out non-EFI wires it's actually not that bad. I just might start doing this for fun!
- IMG_0941.JPG (197.86 KiB) Viewed 2046 times
Re: Steve's 84
Quoting this just because I may have to take you up on this!SteveG wrote:Once you strip down the EFI harness to it's bare essentials and weed out non-EFI wires it's actually not that bad. I just might start doing this for fun!
Re: Steve's 84
I should note that by "fun" I meant MONEY!ChaseTruck754 wrote:Quoting this just because I may have to take you up on this!SteveG wrote:Once you strip down the EFI harness to it's bare essentials and weed out non-EFI wires it's actually not that bad. I just might start doing this for fun!
Re: Steve's 84
SteveG wrote:I should note that by "fun" I meant MONEY!ChaseTruck754 wrote:Quoting this just because I may have to take you up on this!SteveG wrote:Once you strip down the EFI harness to it's bare essentials and weed out non-EFI wires it's actually not that bad. I just might start doing this for fun!
Still a possibility seeing how much I hate wiring. Just get really good at it so you can do it quickly and therefore I get to pay less
