95 F150 - Project Marilyn
Well I have been looking for a nice clean and fairly low miles white, 94-95 F150 supercab, 4x4-- and I finally bought one! This one has 141K, no rust MT truck, is an Eddie Bauer, no ABS (score!), a manual transfer case, and a decent newer aftermarket stereo! It also came equipped with one of the finest pieces of bumper on the front, some CAT mudflaps and all kinds of little trinkets.
So I am wanting to build this truck so that I can have a genuine performance truck that can take to Baja or any of the BITD races, camping, or possibly haul some greasy mess in the back and hose it out later.
I love to see build outlines and how they change so here is what I am looking for:
Exterior:
-Fiberglass fenders F&R
-Prerunner bumpers F&R
-Factory paint that has been touched up to look new and fresh
-Possibly paint the chrome an Argent color or new fresh chrome factory accents
-Window tint
-Baja HID headlights
-LED bumper lightbar - possibly a roof lightbar
-Amber/Blue dust lights on the cab in the factory housings
-Clean every inch top and bottom of factory sheet metal to be free of dirt/road grime
-Spray-in bedliner
Interior:
-Detail speedo cluster
-LED lights in the speedo and cab
-CIPA 36500 rearview mirror -compass, temp and map lights
-6 speaker stereo
-new carpet -black
-new headliner -black
-convert tan to a black/tan
-Reclining suspension seats
-Recover the rear seat to match the front seats
-WInters shifter in custom center console
-Sparco steering wheel
-Race radio
-Lowrance GPS
Chassis:
-Clean, degrease, wire wheel clean and paint with Imron satin paint
-Replace the rivets with 1/2" bolts-Stover nuts
-Delete front gas tank and replace with a 38 gallon tank
Drivetrain:
---Engine-
Replace factory 5.8 with one I already have that has a E-303 cam, 1.7 roller rockers, all new FMS gaskets, hardened pushrods, Lightning tubular intake, 24# injectors, MAF conversion, Bassani or custom exhaust
-Extreme motor mounts
-Saginaw power steering pump
-130amp 3G alternator with Optima battery and 2-gauge battery cables
---Transmission/Transfer case-
-Punisher V/B
-Extreme mount
-Clean cases free of all dirt/road-grime
-Add floor shifter in cab
-Replace slip-yoke t-case with fixed yoke flange style
-VSS conversion
---Differentials-
-4.88 gears
-uni-ball pivot points
-9" wider over stock
-L/S in front, Spool/Detroit in rear
-Ford 9" rear end
-Manual locking hubs
---Brakes-
-Convert brake system to -3AN fittings and SS flex line
-Stock booster (possibly hydroboost)
Suspension (3" over stock height):
---Front-
-2.5" King C/O
-2.5" King triple-bypass shocks
-air bumps
-Limiting straps
-12" longer radius arms
---Rear
-Deaver J40 springs or Deaver 64" spring-under
-Longer custom shackles
-outboard rear shocks
-bed cage
-2.5" shocks -- reservoir or bypass (not sure at this point)
Steering:
-Initially just widen the stock steering
-down the road- convert to swing-set steering
-factory steering box to start out -- then like to look into a 4-bolt GM steering box
Tires/Wheels:
-35" BFG KO2's
-Method 17" non-beadlock race wheels
Re: 95 F150 - Project Marilyn
Once I got this beauty back to the shop I had to ditch the bumper and got right to work removing lots of little things, stock suspension parts, side steps, and the stripes ...
Got the bed pulled off to get started cleaning the chassis, wire wheeling the rails, grinding off rivets, pulling everything off the frame to clean and prep...
BTW-- I must have not taken before pics of the engine and all the drivetrain but it was a HUGE mess of oilcake....
wire wheel chassis.png (68.61 KiB) Viewed 40010 times
wire wheel chass 2.png (67.38 KiB) Viewed 40010 times
Nice score and a lot of progress for a thread start!!
That should keep you busy through the winter!
toddz69
Post by toddz69 »
Looking good! Excellent spec sheet.
Picked this gem up my last trip to AZ....
Love them bolt i 3rg members!
otter
Post by otter »
Looking good. Should have kept the bumper. Haha.
Yea that bumper is for sale anyone would like to buy it lol!!!
So this is me using this as a sounding board-- I set right height by pulling in slowly and stopping slowly; Measured from the bottom of the frame to the floor; measured the vertical face of hub at static stock height with the wheel on; raised the frame 3"; unbolted the stock beams; bolted on 4.5" beam with a guesstimate; put the knuckle/spindle/hub/tire on.
I'm off about 3/16" with too negative caster with 0* eccentrics. By all accords I think it's almost right on the money. Thoughts on that ride height set up method...
FYI-- the goal is to not mess with the BJ area.
Glassworks fenders. I think with the 35's the look is going to be killer!
otter
Post by otter »
That method should be fine.. Just make sure you check for axle shaft clearance. Before finishing the beams.
Got my beams done today --almost :D Still have to plate and brace them all up. 3" over stock height, 4.5" over width and done with molesting the BJ area. Pretty stoked with the outcome!!
Some bling! The race non- bead locks are so hefty and you don't have to do any machining if you wanna use 5/8" studs in the future!
VintageIronFab wrote:Some bling! The race non- bead locks are so hefty and you don't have to do any machining if you wanna use 5/8" studs in the future!
Words. Only words.
Here ya go!!
Not sure why they pics are sideways--- sure would be cool to have an edit function
Looks rad! Those are my favorite methods.
