Bray's 96 Sleeper
Re: Bray's 96 Sleeper
Those sounds like pl the right reason to me!
DMbronco
Bronco Info: 96 XLT 351
Post by DMbronco »
finally getting around to posting some pictures of it on the truck
DMbronco
Post by DMbronco »
then all the new stuff looked so clean, i had to climb under the ol girl, degrease and give her a fresh coat of black...
then onto the steering....
DMbronco
Post by DMbronco »
picked up a Lowrance from Ollie- thanks man!
ordered some 2" diameter roll cage mounts from Axia Alloys...
DMbronco
Post by DMbronco »
Found a smokin deal on a 'newer to me' tuffy box:
any of you guys interested, i'm selling my old one cheap- it also has a riser kit so you can mount off the bed if you dont have or need to tie to a cage- PM me
DMbronco
Post by DMbronco »
Last but not least, pulled the trigger on Car54's full floater 9"- thanks Gary!
Dirt Tech housing, 35 spline 300m shafts, Desert Specialties hubs, wildwood discs..
Called up RuffStuff that same day- CSDrums gave me the heads up on this complete 3rd:
Sweet brother looks great
Are you using the factory spare retaining location as an upper support with a quick release cotter pin?
Very nice upgrades. It's looking bad ass!
hollandermotorsports
This Bronco is very nice in person and the sliding side windows are awesome.
dtbback wrote:Are you using the factory spare retaining location as an upper support with a quick release cotter pin?
It's more like an 'anti-rattle' Will, the tire swing weight is carried by the bumper
Badass! Looks great, Bray!
Makes sense!
DMbronco
Post by DMbronco »
Couple of updates:
Ready to roll that floater under the old girl, so another trip to Richer Racing to do the usual stuff like:
install a VSS kit from Hollander Motorsports
swap u joints on the driveshaft for the pinion yolk
cycle the suspension to check pinion angle, tab for the 2 link, account for bumps
decided to step up to hydro bumps in the rear, so dropped some Bilsteins, cans, and some beffy ruff stuff spring plates off w the truck
DMbronco
Post by DMbronco »
and with some paint:
DMbronco
Post by DMbronco »
while the J40s were apart, I decided to give them some spring love:
I wirewheeled each leaf down to clean steel, hit em with a couple coats of graphite, reassembled and gave em a fresh few coats of black,
Some new Poly bushings in the spring ends while it was easy
Pretty pretty
DMbronco
Post by DMbronco »
Had to swap in 5/8" lug studs up front, found a crack in the driver's side slotted rotor. Bye bye Powerslots, welcome back stock rotors.
DMbronco
Post by DMbronco »
The stock alcoas didn't have enough center bore to work with the new rear hubs, so before I could get to the machinist, I stumbled across a set of 4 non Ford Alcoas,
forged 15" x 8"; already with 4.25" center bore and the 5/8" lugholes I needed.
These look just like the Ford versions, except the lip is solid and there are no holes for the hub cap inserts. The extra 1/2" improves the stance just a bit....
DMbronco
Post by DMbronco »
Ordered some goodies before Sparky gets in and wires the truck next:
A pair of Alpines to match what's in the truck, and an amp to power all 4
and a self powered 250W marine grade Bazooka sub
