![Image](http://tapatalk.imageshack.com/v2/15/02/14/3b0d8cdd5107ed2dbd5fc7b90d806592.jpg)
95 Bronco Build!
95 Bronco Build!
There is a crossmember in front of and behind the tank. Both crossmembers are the same stamping and support where the body mounts are. There is also this major body crossmember that actually creates the clearance issue when moving the tank back. It supports the tailgate and top, so care should be taken if you trim or modify it.
Re: 95 Bronco Build!
How would you clearance then reinforce this if you wanted to move the tank back all the way?
Do you have any pics of how you did it Travis?
What about picking up a spare tank and notching it that way you don't have to cut the support? Would lose less than a gallon in capacity and it would be a piece of sheet metal with a 90* bend.
The notch to move the tank is not a huge deal if you're caging the truck. You can just only do so much with these trucks.
Everything is a compromise. But Ivery always wanted to see a bronco with the same body width but a stretched wheel base. I just reread Kelly's build specs. looks like you could put the bronco right at 110.5". 1.5 in front and 4" in the rear. I think it would be really awesome!!
Body length*
95 Bronco Build!
Couple updates
Cab cage is coming along
![Image](http://i31.photobucket.com/albums/c354/Travisfab/05D9D6DD-36EC-48F6-B85F-08FF82AA13B6_zpsaovp8vip.jpg)
Also picked up a little piece of frame rail to accommodate the stretch.
![Image](http://i31.photobucket.com/albums/c354/Travisfab/448D2352-8850-40CD-81AD-7069E84ED95E_zps4xaw3zvb.jpg)
95 Bronco Build!
Trailing arm pivots
![Image](http://i31.photobucket.com/albums/c354/Travisfab/A2880EAE-E031-4013-9638-569CE1FC23AF_zpsiwcgzfrr.jpg)
- funinthesun95
Sweet
Can I ask why you're mounting your trailing arms on the outside of the frame rail vs. underneath?
95 Bronco Build!
The frame is going to be close to dragging the ground at full bump. I need as much clearance as I can get.
Are you notching the frame too?
95 Bronco Build!
Yes
Doing some work on my bedsides. Like I said in a previous post, the F150 bedsides have way too much over hang behind the wheel well. You can see how much less over hang the Bronco bedsides. I'm basically going to use the tail light area and wheel well from Bronco bedsides, as well as the front strip. Give me a few days and these 2 bedsides will become one!
![Image](http://i31.photobucket.com/albums/c354/Travisfab/DEC4B6AF-0859-4D6C-972D-483AC1B6C028_zps870dhst9.jpg)
- rdcjuanb
Very cool
Get it done already lol. Hey if you need a fiberglass guy I know a guy lol. I cannot wait to see this beast done.
95 Bronco Build!
Come babysit!
Looking good man keep it up
- funinthesun95
Travisfab wrote:Doing some work on my bedsides. Like I said in a previous post, the F150 bedsides have way too much over hang behind the wheel well. You can see how much less over hang the Bronco bedsides. I'm basically going to use the tail light area and wheel well from Bronco bedsides, as well as the front strip. Give me a few days and these 2 bedsides will become one!
you doing fuel fell or tank?
