Rear shock mounts
JonMac31
Bronco Info: 1994, 351w, 2.5x12" Sway-Away (500/600#), Deaver J40 w/ Camburg ext. Shackle/Bilstein 5100 14"
Rear shock mounts
Post by JonMac31 »
Does anybody know where to find this type of rear shock mount?
Phoenix0783
Re: Rear shock mounts
Post by Phoenix0783 »
Autofab and Solo Motorsports for sure. Probably Camburg too.
Threat sells one too. I haven't looked at each side by side to tell you what brand that one is though.
birdco85
Bronco Info: 95 5.8 MAF E4OD
Rear shock mounts
Post by birdco85 »
That's the threat mount. I have the same one
arse_sidewards
Post by arse_sidewards »
Anyone know if any one of these off the shelf mounts clears a pickup bed with no cutting?
IIRC there's a bed support close to where they want to be and going further forward gets close to the fuel tank.
nubreed71
Post by nubreed71 »
There isn't an off the shelf one for the trucks. Believe me...I looked. I've heard 1 or 2 shops have been working on one, but have yet to see one advertised anywhere.
It's possible to get a 10" under there without any cutting or losing the front tank, that's what I'm currently running on my truck. I know Jkrell stuffed a 12" under there also, but I'm pretty sure he had to cut the bed support, and trim his front tank.
10" can be done but it gets tight & the bottom of the shocks mount well below the axle centerline. On my '74, which is similar to an 80's/90's I went with an 8" stroke to keep the bottom of the shocks a bit higher up. Plus with the 10" I'd have had to bump the thing super low. It's all a compromise without going to a long shock & through the bed. You either bump it before the full travel amount to keep the shock from bottoming, or strap it well before full droop. I tried to meet in the middle of the above, but I lost much more droop travel than I did bump travel - on purpose as I'd rather have the bump travel.
IMO the best shock for this would be a set of short bodied 10" (body of an 8" stroke shock, but with the shaft of a 10" stroke).
oh and to clarify - at Taylor said, there isn't an off the shelf thing for trucks. The bronco rear frame is definitely different than a truck rear frame, and then the truck doesn't have the big step up in the body like the bronco. And that step up in the body is where these shock mounts go on the bronco.
Dang we need edit back...
1 more thing to add - Philo has pics in one of his threads on how he did an under the bed shock mount I think, and then I have one on my build thread. Philo used 10" shocks I think. Oh, and Taylor (Nubreed71) might have one in his thread too.
nubreed71
Post by nubreed71 »
Here's a few pics of my setup. It drops out 16.5" bumped and strapped with a 10" shock under the bed:
here's mine. I can't remember what my travel is for sure, but as I said I have 8" shocks & limited bump about 3-4" before metal to metal and droop about 6-8" before metal to metal just to make things work. I have 64" springs designed for a Chevy 2500 on my crew though.
x 430.jpg (69.91 KiB) Viewed 5054 times
Bump is about like this
x 213.jpg (95.35 KiB) Viewed 5054 times
& droop about like this
8-1-12 rear droop.jpg (112.29 KiB) Viewed 5054 times
keenanduran1
Post by keenanduran1 »
JonMac31 wrote:Does anybody know where to find this type of rear shock mount?
I am selling my Threat Motorsports under the bed shock mounts and my 12" 2.5 2 tube race series to go with it. Ready for pick up. Hit me up 949-878-2150
GETSOMEphoto
Bronco Info: 94 Bronco - 5.8 , E4od, Ford 9in, Camburg - beams, coil buckets, Fox, BFG, Mastercraft, Baja Designs
Rear shock mounts
Post by GETSOMEphoto »
What are you looking to get for the package?
keenanduran1
Sold man, sorry about that.
Jbfab
Post by Jbfab »
Honestly the fab on these isnt hard. I have about $50 in materials into mine, i couldnt justify the $450 price tag. Think i have about 3-4 hours into it with cycling. Getting a little over 16" with 12" shocks. Its not a pickup but not realy a bronco either.
JonMac31
Post by JonMac31 »
Is it possible to run a 14" stroke shock with that type of rear shock mount from threat, solo, etc. ?
If I remember right, my buddy had one pretty much identical and he was able to stuff his 14" bilstein 7100's and 5100's under there
Rear shock mounts
JonMac31 wrote:Is it possible to run a 14" stroke shock with that type of rear shock mount from threat, solo, etc. ?
Sure ya can ! The ride would be stiff as heck !. ;)
arse_sidewards
There's nothing stopping you from going lower on the lower mount...
But the landing would be nice and smooth
Rear shock mounts
Stick a 14" stroke shock under your rig, and see how much Bump travel there is !.
arse_sidewards
Andy Jones wrote:Stick a 14" stroke shock under your rig, and see how much Bump travel there is !.
About 14 minus the down travel from ride height... give or take a little since it's probably not 1:1 stroke:travel.
You could stuff it outboard so it's almost parallel to the ground on full compression and keep full bump travel. Not saying that would be a smart idea, but you could do it. The kind of valving you'd use at that orientation would probably cure any axle wrap issues.
