Dez 1990 bronco
Good Knight Racing
Bronco Info: 1990 Bronco prerunner to be
Dez 1990 bronco
Post by Good Knight Racing »
Here is my new project I just picked up will get more photos as I go.
1990 5.8 auto
ford 9"
pro comp lift extended radius arms
35" bfg
17" mickey thompson simu locks
air lift air bags with compresor
bassani headers with offroad y pipe
electric fan
170 amp alternator
rugged radios chease vertex
This is going to be my wife daily driver/chase truck broken race truck recovery vech
Last edited by Good Knight Racing on Fri Aug 13, 2010 3:09 pm, edited 1 time in total.
GKR/ORW/KARTEK/PHILLIPS STEEEL
convoy
Re: Dez 1990 bronco
Post by convoy »
I like it! Reminds me of the good ol days.
Re: Dez 1990 bronco
convoy wrote:I like it! Reminds me of the good ol days.
Before all the insanity?
Re: Dez 1990 bronco
I like it..... clean! Newer style mirrors, no outside tire carrier, no emblems... very nice!
convoy
Re: Dez 1990 bronco
Post by convoy »
Absolutely! :oops:
Good Knight Racing
Re: Dez 1990 bronco
Got a new drive shaft with 1330 to 1350 conversion joint and a 1350 yoke from quick performance.
Re: Dez 1990 bronco
Good Knight Racing wrote:Got a new drive shaft with 1330 to 1350 conversion joint and a 1350 yoke from quick performance.
That just uses a 1350 for the rear joint right? The double cardan is still 1330?
Good Knight Racing
Re: Dez 1990 bronco
Yep that's all I did my race truck uses a 1350 yoke so I was setting this up if ever I need a third member bad I could swap it out of the bronco into the race truck.
redwagon
Re: Dez 1990 bronco
Post by redwagon »
Nice, but I think you mean 5.8
Good Knight Racing
Re: Dez 1990 bronco
Nope you didnt hear about the 1yr only special model 5.9 with the muffler bearing and headlight fluid. HAHA
Re: Dez 1990 bronco
Good Knight Racing wrote:Nope you didnt hear about the 1yr only special model 5.9 with the muffler bearing and headlight fluid. HAHA
If you need a source for muffler bearings, i've found these guys to be pretty cheap! http://kalecoauto.com/index.php?main_pa ... ucts_id=10
Good Knight Racing
Re: Dez 1990 bronco
Painted the beadlock rings black
tr 001.jpg (118.92 KiB) Viewed 2818 times
Good Knight Racing
Re: Dez 1990 bronco
Made some new radius arm mounts.
Good Knight Racing
Re: Dez 1990 bronco
Some paint on it to keep it from rusting.
Good Knight Racing
Re: Dez 1990 bronco
How it mounts into the beam.
Good Knight Racing
Re: Dez 1990 bronco
Good Knight Racing
Re: Dez 1990 bronco
Re: Dez 1990 bronco
looks good!!
Re: Dez 1990 bronco
Post by shockseals.com »
You will need to grind quite a bit to get clearance for a 1350 at full droop. They dont have as much angle as a 1330. The 1330 with large caps requires quite a bit of grinding at full droop to = a stock 1330.
Rear u joint is limiter on droop once you go to deavers or similar but if its a spare for the race truck...you gotta do what you gotta do.
JERAD121
Bronco Info: 95 EX BORDER PATROL BRONCO. 6'' LIFT 35'' BFG. 4.56 GEARS STOCK LITTLE 302
Re: Dez 1990 bronco
Post by JERAD121 »
Looks good man clean looking bronco.
