A pair of 74's...
Re: A pair of 74's...
Looking good. Glad to see you working on it agian.
ChaseTruck754 wrote:according to my calc's based off the cad drawings it's 44.785 gal.
With all the baffles in I'd say 43-44 gal. = good for road trips but hard on the wallet when I do finally go to fill up.
And I only popped out the exact # because I was made fun of by a buddy here for my cad drawing & breakdown of the tank seen below. I'm a bit anal on this stuff I guess, but it does help me build. I spent a ton of time on this silly drawing, but it seems to be worth it in the way it's coming out.
Your CAD skills are very impressive!!
Thanks guys. I haven't really stopped working on it so much as it's just very sparatic as to when I have time. I have been VERY lazy about posting updates here though.
And as for my cad skills - I get paid to do that, it just comes in very handy for drawing trucks parts as well!
Can't believe that upper radiator mount is almost two! Where the hell does the time go?
No clue man. But it does seem to disappear quickly somehow!
Oh and for something else that IS two - not almost...
Started final welds on these bad boys the other day, went to save these pics & realized the last time I had touched them was 2 years ago - almost to the day!!!!
Too bad my laser cutter quit on me so turning out bitchin looking parts like these is less likely to happen now :( Although I am using more and more stainless on the truck after parts like this :D
Driver 1.jpg (108.06 KiB) Viewed 2340 times
Driver 2.jpg (93.75 KiB) Viewed 2340 times
Oh and here's a little bit from today. Currently upset with myself for violating the "measure twice, cut once" rule. It was more of a "cut the part long & shorten til it's right" infraction, but it has me frustrated with myself.
Has a little bit to work before I had to get the monkey so I was trying to bust out some radiator hose work since I got the parts yesterday. I got 3 of my 4 cuts done on the lower hard line & was on a roll so I quickly looked at the 4th, said "that'll be good" and cut it before I had to wrap up & go grab the kid. I cut the tube a bit short so now have to weld a piece back in. Not the end of the world as just 2 welds in this lower tube vs. 1, but it annoys me.
The stupid angle they put this lower radiator hose tube on is making this harder on me as the hose will be REALLY close to the belt.
Here's upper & starting on lower
And here's lower - mostly finished, but just a bit short.
Nice
good that you have found a little time to work on it.
Flip the legs around some and see if that works. I am guessing you are wanting to suck that 90* elbow into the radiator so theres not such a kink in it right? If the flipping around doesn't work looks like splicing a small straight piece in along with some good ol' fashioned metal finishing :-)
pushing that 90* hose towards the radiator causes MORE of a kink. The tube coming off the radiator there is at a 45* angle or so toward the center of the vehicle. It was making my life difficult!
What is hard to see, but can be seen in the 2nd pic is the puller for the AC compressor under the tensioner. This is what I am worried about the belt being close on. I did have to push that 90* hose toward the radiator more & put a little kink in it, but I'd rather have a kinked hose than one a belt will wear a hole in.
Got the tube cut & tacked up & ready to be welded on lunch. I'll weld it tonight.
squirelmurphy
Post by squirelmurphy »
Keep knocking things off that list! It's looking great.
ChaseTruck754 wrote:pushing that 90* hose towards the radiator causes MORE of a kink. The tube coming off the radiator there is at a 45* angle or so toward the center of the vehicle. It was making my life difficult!
Cut the tube off the radiator and give it a better angle.
Thanks Mike.
Brian - I contemplated it, but I'm a chicken!
I've thought about just cutting the tube shorter, V cutting it then pulling it back a bit to make it straight & re-welding, or cutting it off completely & welding on a straight tube.
I decided not to for a few reasons.
1) trying to keep debris/metal shavings out of the radiator when cutting is difficult. There are things that help with this (turning the radiator tube down when cutting so metal falls down/out vs. in), but it's hard to be certain nothing gets in the radiator.
2) The aluminum on this this is really thin & I'd hate to blow a hole welding it up & be chasing that. Yes I can weld aluminum, but I'm not the best at it and am a bit out of practice - so I chickened out.
I spent a bit of time on lunch messing with this some more & have the tube cut & tacked up. Will do final welding tonight I believe. Tried to take pics but my phone is out of memory AGAIN. Been this was since the little one was born - too many pics
oh yeah - reason 3 to add to above. If I ever mess up this radiator & have to order another one I'd have to weld the tube on the radiator all over again!
I'm guessing you're going to end up using one of those donuts with really tight radii to make the hose less kinked but I could be wrong on that :-)
naw - I used what I had ordered originally for it = 1 2.5" CLR 90* bend and 1 3.0" CLR 90* bend. Looking at it now 2 2.5" CLR bends woulda been a little better, but it's almost done. As I said it's all tacked up & ready to be welded. Fell asleep on the couch last night before the wife went to bed so didn't get any welding done.
Contorted lower radiator tube finished up
Also welded up the batt. boxes, although now part of me is thinking I should just set up a dual batt. box on the driver's side like I've seen some guys do.
I'm thinking I'll just run 1 batt. for now and put the BHAF where the pass side box was. I can then build a 2 batt. box & add a second batt. later on if I want/need.
Time to get to finishing up the support brackets for the AMP step mounts, running the e-brake cables & then either looking at the twin stick shifter setup, headlight mounts, fuel line run or the air intake. So many "little" things left to keep plugging away at!
Quailhunter
Post by Quailhunter »
Steve, do you have any pics of a super cab or a crew cab with a flat bed chase rack type of setup?
Thanks
ChaseTruck754 wrote:Contorted lower radiator tube finished up
Bitchin!
Very nice man. How long till she turns over? Looks like your getting pretty close now.
Quailhunter wrote:Steve, do you have any pics of a super cab or a crew cab with a flat bed chase rack type of setup?
Thanks
Don't think I have anything with a flat bed/chase rack Rob. Ive got a pic of a crew with a utility bed, & then pics of Greg's 78 yellow truck with a chase rack, or then pics of my crew and supercab when each of them had the chase rack on, but I think that's it. Flat bed pics are easy to find, but not the desert chase truck type setup like you are thinking.
dtbback wrote:Bitchin!
Thanks
Rmc wrote:Very nice man. How long till she turns over? Looks like your getting pretty close now.
No clue. I'm getting closER, but still lots of little stuff to do. Been doing a few small things, but not much worth mentioning or posting pics of. Stuff like trying to work out the e-brake, brackets for my AMP steps, etc.
I did paint the exhaust black with high temp paint though. The one section of aluminized steel that was a different color was bugging me. Plus this makes it hide a little better
Exhaust painted 3-10-15.JPG (114.58 KiB) Viewed 2175 times
Quailhunter
Right on.....Thanks.
I love how you are running the exhaust, very slick Battery boxes double slick!
