Tank from a F450
Sway Bar mount and Tank Tube work......
tank dave23.jpg (31.1 KiB) Viewed 2729 times
tank dave 32.jpg (28.75 KiB) Viewed 2729 times
tank dave12.jpg (29.8 KiB) Viewed 2729 times
That's sweet. Also my plan if the SF 35spline lets me down. Who of making the shafts?
cypher
Post by cypher »
Well done.
Front end about done Solo axles test fit on Dana 44/50 Beams
Solo Axles test fit
Solo Axles test fit
dave bronco beam 4.jpg (33.48 KiB) Viewed 2651 times
Solo Axles test fit
Solo Axles test fit
dave bronco 44 50 beam axles 3.jpg (25.93 KiB) Viewed 2651 times
solo Axles test fit
solo Axles test fit
dave bronco 44 50 alxes test 2.jpg (26.88 KiB) Viewed 2651 times
Dave has skills
roof patch..... had some rust he cut out.... nice and clean patch
dave bronco roof patch 2.jpg (23.02 KiB) Viewed 2651 times
dave bronco roof patch 12.jpg (22.02 KiB) Viewed 2651 times
Does he do Expeditions?
lol I should ask .....he got the roof line from A& B they cut it and delivered it.... tho it would make your repair easier
Ok, So this might be crazy talk, but I am going to ask anyways. Since using the Dana 50 outer housing and other housing component's, are Dana 60 components adaptable to this setup. If so, could 40 Spline axles be retrofitted in place? I don't know if anyone makes a 40 spline limited slip? But then use 1410 u joints at the knockle with custom 40 spline locking hubs. Like I said, Crazy talk. It was just one of those ideas that jumps into my head at 3am. I was just thinking of a bulletproof long travel ttb front end.
ALL good
yes Dana 60 stuff works.... Dana 50 already over kill tho....lol
A version of this thought was in the plan but after research...........priced everything out..... RCV axles seems to be a better option less custom Fab and more off the self parts used
our 44 stuff does well....... the 50 idea was why not..... bigger everything but it is also heavier so un sprung weight could come into play.. but our trucks are heavy anyways
time will tell
I was just thinking of Chris Wilson's issue with the front end breaking. Part of the extra wear on his is the 37" tires weight and how hard he pushes it. I have run 35" tires most of the past 23 years on my Bronco with the last 13 pushing it pretty hard since it is a trailer queen now. I am rebuilding my whole front end and may make the jump to 37" tires, thus the reason I am in overkill mode of thinking.
Seabass
Bronco Info: 96 bronco
Post by Seabass »
Updates?
Seabass
I just bought this..... Haha
more to come
Seabass
Post by Seabass »
Nice!
it look like this is the plan......to start is
1996 7.5l 460 OBD2 with vortech supercharger,and doug thorley headers
C6
NP205 tcase
new drive lines
plumb
wire
dash
drive it
I am trying to get long drive shaft and we will see it is looking like I could be in the 25-26 inches with rear frame kick and c6 np205........ and not doing stretch as all the sheet metal work is already done.
then
tire carrier on back out side for 2 spares
more plan to come
need input
stay 89-91 or go 92-96
I have front clip for both.
No brainer.... 92-96!
we will see how this thing turns out. I hope to have it on the road in the next 3 months.
fuel tank skid and sway bar set up
link radius arm pivots
safety cage..... and rear shock mounts ....fuel tank can
third seat location
