92-96 Headlights with Bi Xenon Projector Conversions!
Re: 92-96 Headlights with Bi Xenon Projector Conversions!
Heads up!!!
1 Pair of 92-96 Crystal Clear Headlights..... Standard Projector retrofit with Hi low HID. $260. Only one set at this price.
- tlatoolman
- Bronco Info: 1994 Bronco 6 inch lift convertded to Mass Air Flow looking to re do front and rear to long trivel
HI i need a set but ? do they come with all the adj/mounting hardware if not i need a price for HID in clear
Sure do, PM me and I'll get you set uptlatoolman wrote:HI i need a set but ? do they come with all the adj/mounting hardware if not i need a price for HID in clear
What?! I want halos! Dammit T!
yikes wrote:What?! I want halos! Dammit T!
You are far from a Saint B..... sorry, no halo for you!
************Deal Alert************
I have a lightly used pair of projectors, and slightly used pair of ballasts. Nothing at all wrong with them. I am throwing this all in a brand new set of housings (Clear) with brand new projector shrouds, bulbs, and wiring harness. This is a one time deal! The projectors have very little use, came out of Vics vehicle, we swapped his headlights to square projector. One time deal, $240 bucks. Additional $20 to ship anywhere in the US. Will knock $30 off if you already have HIDs.......
$210 no HID kit
$240 with HID kit
$210 no HID kit
$240 with HID kit
Can I make payments? Hahatcm glx wrote:************Deal Alert************
$210 no HID kit
$240 with HID kit
birdco85 wrote:Can I make payments? Hahatcm glx wrote:************Deal Alert************
$210 no HID kit
$240 with HID kit
Sure, 100 up front, balance 2 weeks out. PM me
$210 no HID kit
$240 with HID kit
This deal is spoken for.......back to 20 percent off.
Thanks
TennesseeMike
- Bronco Info: 1990 stock (so far), rebuilt 302 engine, 5speed M5R2 tranny, rebuilt ford 8.8 rearend.
Have you had a chance to mess with any 87-91 headlights?
Still messing with them Tennesseemike, but getting a manufacturer to build me a clear lense, at a decent price has been tough. Still in progress though.
Alright, sneak peek at the 87-91
Several problems with these
1) Expensive, when all said and done, you would likely be in approx 750 bucks
2) Requires lexan or polycarbonate lense to be cut, and fit into the headlight
3) I worry about sealing correctly, the leexan would be silicones on, then screwed in on all four corners. Too much silicon, and you will see it, not enough and it will leak
4) expensive!! (Did I mention that already)
Anyways, figured I drop a sneak peek.
Oh, the housings are huge!!!!! I would definitely do square projectors, with a bigger shroud. I just didn't have any in stock to test fit.
TennesseeMike
Looking good, I will be one of your first customers...
TennesseeMike wrote:Looking good, I will be one of your first customers...
Mike, you will officially be the first with these, expect to finish within the next week!
