I am built bronco tough and this is my thread of my built 90
Broncotough
Bronco Info: 1990 302 aod. Leveled lift, re gasket engine, resto-mod
Re: I am built bronco tough and this is my thread of my built 90
Post by Broncotough »
Imma use drop down brackets, and bigger coils.
I know the drop-down bracket lifts come with longer radius arms and drop down brackets for them. You're going to need some radius to do the lift right .
Broncotough
. Got creative with 4x8" sheets of plywood. Custom bed drawers.
how overland of you! I dig 'em!
Broncotough
It still needs to slide tho. One using those easy movers that can be placed under furniture to help move um. But want to use real drawer tracks.
Broncotough
out of curiosity, what engine oil do you guys run?? Ive heard Lucas Vs royal purple but royal doesent have a 10W-30 i think.
10-40 in the winter and 20-50 in the summer.
Whatever the factory put in them is what I run... in all my cars. But, I live in paradise, so climate is not a factor. Central Valley... I'd still run factory weight. Brand... just something good. Valvoline, Chevron... basically, whatever we kept in bulk at the shop. These days, I'm considering switching to synthetic since I'll be doing it on my back and want to do that as little as possible.
Royal purple 10w40.
Broncotough
philofab wrote:10-40 in the winter and 20-50 in the summer.
Why 20-50 ?? the viscosity and cause its hot in the summer??
Philo lives in bullhead and summers there are brutal.
Broncotough wrote:Why 20-50 ?? the viscosity and cause its hot in the summer??
It gets hot here in the summer, sometimes almost 130F. Running a thicker oil is bad for economy but good for bearing life and oil pressure. I've always run a thicker oil then recommended and gotten ridicules life from my engines at the cost of fuel mileage. I should mention I am rough on equipment and it's not uncommon for me to run for ling periods at 4K+ rpm or bounce off of the rev limiter.
Broncotough
Wow 130! That's hot, I can defiantly see that for a racing application.
Broncotough
on the truck!
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Looks good. I like the way the high lift mounts
Broncotough
Thanks!! imma weld a small plate for the jack to bolt to behind the tire. theres just enough room.
Just a little FYI with the High lift. When they are uncovered and outside all the time the jack has a good chance of not working when you need it. I use to carry mine on my roof rack and now I have two rusted ones sitting in the garage. One day I want to sand blast and rebuild them. Now I have a Craftsman aluminum floor jack inside. I am going to mount mine inside to the cage.
Broncotough
Imma line x mine along with the bumper. I've also considered a cover for it. Good point wrightracing.
Broncotough
Imagedeffently gonna add one of these!!
The problem is the springs and the pins rust and if you line-x those, it will not function either. The hard cover is the best protection. I guess I lernedd a bit after having me Bronco far darn near 23 years.
Note the poor Grammer and spelling, was intentional.
