I am built bronco tough and this is my thread of my built 90
Broncotough
Bronco Info: 1990 302 aod. Leveled lift, re gasket engine, resto-mod
Post by Broncotough »
This is my beast of a snowball, just getting bigger and bigger and mre costly with every dollar i spend! ive had it since late july 2012 for $750. YEAA!! 302/aod level kit, a list of small isues too much to list, BFG ATs 33''x 12.50'' on AM Racing 15'' (i think) Bajas. custom paint, interior is being designed, as well as a new suspension, and bumpers.
Re: I am built bronco tough and this is my thread of my built 90
Nice...welcome
Broncotough
Just installed rocklights on the front, still need to do the back. and i discovered the power of financing..........
Broncotough
Still have a rough idle event go I have changed out the low pressure fuel pump, O2 sensor, and idle control valve. So imma guess it's the high pressure pump going out.
Did you clean the carbon and buildup in the passage to the Idle control Valve and the butterflies in the throttle body. Also check the EGR valve and clean it out.
Broncotough
Yea i sprayed cleaner in the throttle body and all around it. My idle is at 600 700. when i shift into park from drive it dips below 500 snd occasionally dies.
With the carbon build up you really need to use a brush to really get it cleaned out. I am not sure what my 302 idle was at but 500 or 600 seems close when warmed up.
LvSteve
Post by LvSteve »
Looks good , Check your fuel psi at the rail , whats the fuel filter condition
Good call, tcinu2. That always seems like a automatic thing for me when running down a diagnostic issue.
Broncotough
Yea actually the psi I Disney think of. It's a new filter I put on last year, 6/16/13. I wrote it in the filter when I installed it. The brush is also a good idea to get that xtra gunk off of it.
Broncotough
beginning my bumper build. First time officially using a hi lift
Waiting to see what you turn out!
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Where did you get the spindle from?
Broncotough
Comp 4x4. 1000lbs
Cactus Cooler
Post by Cactus Cooler »
Thinking of doing the same thing with my bumper, I was going to use a Heim at the top and have it connect to the cage inside.
Cactus Cooler
How tall is the main body ( the part with Zirt fittings)??
Broncotough
4.5''.
Broncotough
Would i need new radius arms with a 4'' lift?? also new drivelines?? Im kinda hopeing not..
Broncotough
. New gear!!!
How are you planning to lift your bronco? Cut and turn beams or drop down brackets?
Longer radius arms are a much needed improvement. Your drivelines don't need to me modified.
