Blueblood
Post by Blueblood »
a view of the south end of SLO from the top of Madonna Mtn
Good eye!
My brother just got married on the Madonna Mountain this saturday and the reception was at the ranch. It was awesome. Such a change of pace up there (Los Osos) compared to SD.
... One step closer.
Nice Robert
Custom rotors, too?
Those look like the Dodge rotors I am running...
Yup, correct philo, same diameter and thickness as wilwood but 1/16th the cost.
Rmc wrote:Yup, correct philo, same diameter and thickness as wilwood but 1/16th the cost.
Did you have to bore the center? I machined all four to fit over my D60 hubs without trying them on the 44 hubs.
Ya I did. I had to open them quite a bit. Now to the wheel studs.
philofab wrote:Did you have to bore the center? I machined all four to fit over my D60 hubs without trying them on the 44 hubs.
You have the 5 lug d60 hubs on the bronco?
On the rear, yes. Front is still 44 hubs.
ahh. got it
Its going to be rotor over hub?
That's my goal Andy, to make break inspections and replacement ect easier. I can duplicate factory style ( press together) but I don't really see an advantage.
Rmc wrote:That's my goal Andy, to make break inspections and replacement ect easier. I can duplicate factory style ( press together) but I don't really see an advantage.
Thats AWESOME!! SOOO much easier that way. Love the stuff you're doing.
Rmc wrote:to make break inspections and replacement ect easier. I can duplicate factory style ( press together) but I don't really see an advantage.
Other than your poor scrub radius getting even worse?
Which can be corrected with more backspacing on the wheels.
It's a 1/4" at most, castor curve in long travel is harder on steering than 1/4" of lost scrub. Correct me if I'm wrong but scrub advantage is lost in the extreme camber changes anyway right?
Rmc wrote:It's a 1/4" at most, castor curve in long travel is harder on steering than 1/4" of lost scrub. Correct me if I'm wrong but scrub advantage is lost in the extreme camber changes anyway right?
No, it always makes a difference. The tie rods see really high loads while turning. The vehicle leans but the tires stay fairly flat due to the caber curve of the beam.
