knuckle Taper Adapters
Post by shockseals.com »
Anybody know who makes taper pins for the steering that have a 1/2" stud? Preferrably heat treated 17-4?
Anybody know the TRE taper?
Re: knuckle Taper Adapters
shockseals.com wrote:Anybody know who makes taper pins for the steering that have a 1/2" stud? Preferrably heat treated 17-4?
The TRE taper is 7 degree if I remember right. You would be better off drilling for a F-911 bolts with misalignments. I think a 5/8 ends up working well.
Years ago, someone told me Kartek used to stock them. This was when they were first getting into truck stuff, so it's been a while. I don't have any idea what they were made of, though.
I found 1.5" per foot which is roughly 7.125 degrees. I will measure when i get home. Either should work.
I will be running misalignments. Drilling it sucks for the sole reason if you break a knuckle in the middle of nowhere and happen to get a knuckle...its that much more hassle to get going again. I was going to drill and double shear it but thats just over the top.
Leduc uses this stud/taper adapter set up on his x-over steering but he doesnt return calls. I know of a few leduc broncos running it without issue.
shockseals.com wrote:I will be running misalignments.
You might not need a spacer at all as there's not a lot of misalignment. If the geometry is good you might be able to put the heim right on the knuckle.
shockseals.com wrote:Drilling it sucks for the sole reason if you break a knuckle in the middle of nowhere and happen to get a knuckle...its that much more hassle to get going again.
Exactly. Keep it simple. I didn't know Leduc used studs in the knuckles. It makes a lot of sense to me and I'm surprised we can't buy them at just about any desert off-road shop.
shockseals.com wrote:I found 1.5" per foot which is roughly 7.125 degrees. I will measure when i get home. Either should work.
IFAIK there is only a 10 and 7 degree taper used on balljoints/tie rods. It should be 7 degrees.
Keep trying on contacting Leduc. He is a very busy guy, I have his and his sons cell number if you can't get a hold of him. PM for them.
kartek sells a "9/16 taper" adapter for buggy guys. I dont even know WTF that means. It works out to be a 5 degree taper after I had him give me all the dims since I didnt know WTF 9/16 taper meant. They "dont know what material its made of but people have used it in the baja 1000" and they've "heard or ford guys using them in knuckles"
shockseals.com wrote:They "dont know what material its made of but people have used it in the baja 1000" and they've "heard or ford guys using them in knuckles"
Well if it's good enough for the most grueling point to point race in the world then it's good enough for YOU Mr. customer.
11wnb
Bronco Info: 93 EB 5.8 daily driver
Post by 11wnb »
Check out BCBroncos.com. It sounds like this is what you are looking for. http://www.bcbroncos.com/steeringlinkage.html
11wnb wrote:Check out BCBroncos.com. It sounds like this is what you are looking for. http://www.bcbroncos.com/steeringlinkage.html
Thanks. Thats close, but for independent suspension it needs to use misalignments not just bolt straight to the heim like that.
You might want to measure the amount of misalignment, Kris. If you can't go straight to the knuckle with a heim you could probably get away with a really small spacer between the two.
EDIT: With the stock steering, the driver side wheel has tons of misalignment at the outer tie-rod end, the passenger side (which is duplicated with a single swinger) has little misalignment.
Note the lack of spacers between the heims and steering knuckles.
MOSS2
Post by MOSS2 »
These probably arent exactly the geometry you are looking for but Speedway may give you a lead if you give them a call. Maybe Stock Car Products or Affco also.
http://www.speedwaymotors.com/Adjustabl ... ayId=35534.
Fodrill makes them. 4130 heat treated...picked them up from ORW.
I also picked up a lot of 8 of them since it was a good deal this week...if anybody needs a set let me know.
Prerunbronc
Bronco Info: 95 bronco 5.8 coilovers, deavers, 2.5 fox, full glass, air bumps, 9" rearend
Post by Prerunbronc »
I have bought some from mckenzies for other projects
I'm confused, what exactly are you doing? Sorry for the stupid question, just haven't been around long enough to know.
hobbyturnedobsession wrote:I'm confused, what exactly are you doing? Sorry for the stupid question, just haven't been around long enough to know.
He is replacing his stock steering with hiem joints without modifying his knuckles.
I kind of got it. That replaces the tres right?
toddz69
Post by toddz69 »
hobbyturnedobsession wrote:I kind of got it. That replaces the tres right?
Yes.
