Another Bronco Build
ChiroMatt
Re: Another Bronco Build
Post by ChiroMatt »
9" trussed
Q80's
New u bolts
Threat upper shock mount
Foa 12" triple bypass with reservoirs
ARB air locker
Disc brake conversion
New rotors and studs
ChiroMatt
Post by ChiroMatt »
Side view b4 trimming of the u bolts
And rotating the rear shocks
Gonna need a shorter muffler....
Any recommendations ????
( exhaust idea ) Out the side in front of the rear passenger side tire and straight pipe or single chamber flow master. You could use a flow through magnaflow also ( the cherry bomb style). If you look there's some sheet metal you cut away and there's a straight shot to the side just above the passenger side front leaf bracket. Quite a few have done it at this location.
ChiroMatt
Post by ChiroMatt »
RMC,
Of the mufflers you mentioned which one is the quietest?
Robert that real estate is usually taken up by the upper shock mount unless I'm thinking of the wrong location
ChiroMatt
Post by ChiroMatt »
Autofab motor mounts are not simply bolt on.
ChiroMatt
Post by ChiroMatt »
Tools you will need:
Impact wrench
Various sockets
Impact angle sockets
Impact drill
Torch
Hammer
Engine lift
Wedges
Angle grinder
ChiroMatt wrote:RMC,
Sry man just saw this. The magnaflo have a vroomy sound at normal pitch. The flow masters seem to be bassier. Both are audible when on the gas. You could go for a longer magnaflo can style and it shouldn't be that loud lul that makes you drowsy. I'd go magnaflo if you want quieter.
Uh you may have an issues. Mine were simply bolt on man.
ChiroMatt
Post by ChiroMatt »
I definitely have issues!!!
Or else I wouldn't be building a bronco!!!
ChiroMatt
Post by ChiroMatt »
The front beams are in and the cage has been mounted.
Think the Beam c/o mounts will need to be moved...???
Will see
ChiroMatt
Post by ChiroMatt »
All taped up.
Ready for the cuttin wheel!
Are you the one that bought the bedsides from Andy (Slvrslk)? Hopefully as no paint needed on them if so!
Cactus Cooler
Post by Cactus Cooler »
ChaseTruck754 wrote:Are you the one that bought the bedsides from Andy (Slvrslk)? Hopefully as no paint needed on them if so!
Nope, that would be me. Already started fixing the sml glass scratches and cracks.
Well you got a good deal then. Just unfortunately you'll have to paint them most likely. As you know they match the truck above perfectly
ChiroMatt
Post by ChiroMatt »
Measuring front end before removing fenders.
ChiroMatt
Post by ChiroMatt »
Getting the front end burned in.
Cycled several times, lots of measuring.
This is my first TTB build or any build for that matter, learning lots.
ChiroMatt
Post by ChiroMatt »
Passenger side. Hopefully got the full bump set up right.
ChiroMatt
Post by ChiroMatt »
Trimming and hanging the rear glass.
Almost cried cutting up such a clean rust free body, sniff sniff!
So much for the original sleeper idea...
Haha, I'm over it, looks awesome with the wider glass!
Any ideas or thots on painting and colors???
