Willie's.....1992
Re: Willie's.....1992
Hahaha, that's awesome!! my 2 yr,old lives the Bronco!
I remembered this thread last night. Don't know if this helps but this is the setup on my in-laws way overbuilt duramax.
It helps a lot
Custom mastercraft for Zoey?
If you want I can get a on off it for you. I don't know if something like that ump may work but I do know it takes a Donaldson filter
Nick wrote:Custom mastercraft for Zoey?
yes,
Steve (Chase Truck) hook up some seats so going to work on a good set up for her I'm hoping to match the mastercraft I got
Going to sell the 3 3G I have It looks like
yes,
Good Dad!
Keep your eye on CL, & RDC for the kids seats as they do come up. I scored one for Katelyn not too long ago off CL.
I figure that setup would be more than sufficient. Plus its not monstrous.
hobbyturnedobsession wrote:I figure that setup would be more than sufficient. Plus its not monstrous.
yes working on the info numbers now .....does the turbo forced air change the flow? you think
I would think most certainly. My father in-laws truck pushes 38-42 lbs of boost at close to wot and that means a lot more air. I'm not sure by how much but you figure the displacement alone is bigger than a stroked or mild 351w.
funinthesun95 wrote:does the turbo forced air change the flow? you think
Does it ever, your flow will roughly double at 15PSI.
Price on that set up?
update on air filter and Box.......I am going to use the 7 layer filter and a foam rap
here are pictures with out the foam rap
we will see how it works
it is a 4 inch tube/opening and fits the bolt on adaptor for the MAF set up.
Nice
we will see how nice it is......I will give feedback once we get some miles on her
I liked the ump above but was not sure I was ready for a redo on moving items in the engine compartment yet.
Plan is to daily drive the bronco for next 10 days then take this bad boy down for the CODE race and get some dirt miles on her. Mexico but still 60 min from home lol
took The bronco to Bill mobile (my Buddy Shop) for a good look over today
bronco test drive.jpeg (41.31 KiB) Viewed 1022 times
Looks good. Should buff it out . I like those wheels ; )
NICE... I want to see the after pics :-)
