snowman429's 93 Bronco v2.0
Re: snowman429's 93 Bronco v2.0
Looking great!
snowman429
Post by snowman429 »
Thanks
snowman429
Hey guys, been awhile since I posted anything and worked on the Bronco. I've been busy with other stuff. Anyways started back on the Bronco today. I decided to start installing the rear springs and shock mounts. Well shock mounts in but I ran into a problem with the rear springs. Do you have to move the rear hanger back when you install q80's? I'm using threats extended shackles. With the spring just hanging under their own weight my shackles are almost vertical. Thanks
snowman429
Never mind, I figured out what I did.
snowman429
So got the rear suspension mocked up and started on the front. I need to see if one of you guys can take a measurement for me. Since I'm going from a solid axle back to TTB, I need the measurement from that pin on the underside of the frame back to the axle centerline. Thanks in advance.
snowman429
Here's a couple pictures of what I've done lately. I have to drop the shackle hanger down about an inch so the shackles will clear the body. Figured out where to mount the radius arms and bolted them on. Next will be the coilover mounts.
-JD5353-
Post by -JD5353- »
I know it's alittle late but for your axle center line question, usually
Most push the beams as far forward as possible for clearance. I would do that, then measure wheel base on each side and measure across to make sure everything is sqaure, and call it good to go.
snowman429
That's pretty much what I did. Thanks for the reply.
snowman429
Well finally getting some work done to the bronco. Got the engine cage mostly done, still need to add a cross over bar between the hoops. Manged to get the coil overs mounted today and picked up the new tires.
ChiroMatt
Post by ChiroMatt »
Looking good.
Are those 35" or 37"?
FOA c/o?
If so I'm running a very similar build out, and experience getting the parts!!!
I'm guessing 35s, not sure anyone makes a 37x12.50r15 anymore
ChiroMatt
Post by ChiroMatt »
Falken wild peak at come in 37" by 15" wheels size still. Reasonably priced too.
Anyone running these in this size ? What do u think?
snowman429
Yes they are 35's, and foa's.
I ran the wild peaks in a 35" (315/75r16) and loved them. Strong s.o.b. of a tire.
snowman429
Couldn't wait had to set the glass on to see what it was going to look like.
ChiroMatt
Post by ChiroMatt »
Looking good.
Did u replace the plastic that runs across in front of the radiator?
More pics please.
snowman429
Not sure I know which piece you're talking about.
snowman429
Well since the weather isn't cooperating, (to cold to ride my bike and not enough snow for the snowmobiles), I've started working on the bronco again. It's headed to my buddies shop to get the cage finished up and a couple other things. So in the mean time I decided to get the gears installed in the rear end and set the pinion angle. More pictures to come soon.
Tanner287
Post by Tanner287 »
Yeah get it finished and post some more pictures! I really like the truck man
snowman429
Thanks, I have family coming up here for the 4th of July with their sandrail. I told them I would have the bronco drivable by then, so now I have a deadline.
