94 Raptor killer
Re: 94 Raptor killer
Looks good man!!!
cs_drums wrote:I also swapped out my 0* alignment cams for 0-2.5* adjustable ones. I have them adjusted all the way out and still -3* at ride hight! I wanted it low buty beams were not built for the current ride hieght. Im frustrated. Is it ok to run the ball joints that tapped out? I guess I'm destine to ruin tires!
Bottom ball joint moved out to far..........
I ran the 2.75* eccentrics without issue.
Nice GPS!
BDKW1 wrote: Bottom ball joint moved out to far..........
Good to know, thanks. They are a lot closer than they were. My beams are all custom from the 3rd out to re-c&t isnt really an option unfortunately.
I guess I'll just have to start on my equal length 4wd setup ; )
Rmc wrote:Nice GPS!
Old school black and white but its better than previous... guessing/hoping navigation method! Im stoked with what I can afford!
I talked to CHO, he said they built my beams off Geoffs old truck that ran the 6" shackles. Im running the 8" so thats why. I set ride hieght a smige taller and they are on the money now. Minimal So-Cal lean. haha
So the 94 is mid way through a major rework and what's better for progress than more projects, right?!
Baby girl on the way! Got to make the wife happy...
Remodel master bedroom with walk in closet.
Remodel office into nursery.
Oh and she wanted a bronco too...haha
Plan to keep it minimal and simple. Some 33"s, limited slip or locker in the rear and get everything dialed and reliable. Dirty but super complete. Need to address a cooling issue and none of the window regulators work. It was missing a top which I had and has been stored inside for several years.
Should have them both ready before next season.
Nice! My wife wanted one too. She's got a 96 and wouldn't get rid of it for any vehicle.
Congrats on the little one on the way! Good job on picking up the bronco for wifie. Happy wife happy life.
What did she drive before the bronco?
Ford Freestyle. Not a bad vehicle it's just getting up there in miles and when the dealer quoted $1000 to replace the water pump and $1300 to replace the A/C compressor I started to not like it as much.
I am gonna probably buy another Focus in the next few months for her DD but we need a big family wagon. I plan on adding a from split bench from a f250/350 so the bronco can hold 6 (same as the freestyle.
otter
Post by otter »
So what's up with the bronco in the background with the roof cut off? New build?
drewbee88
Post by drewbee88 »
otter wrote:So what's up with the bronco in the background with the roof cut off? New build?
that's what i was thinking. all i saw was the convertible bronco in the background!
Parts bronco. Getting all chopped up. If anyone needs any of it let me know.
otter
Post by otter »
So what's getting reworked on your Bronco? Post some updated pictures.
cs_drums wrote:Parts bronco. Getting all chopped up. If anyone needs any of it let me know.
Can you cut me a 12"x12" piece of the rear floor out?
I'd take one as well :-)
Can I cut a 12"x12" piece of the rear floor out?
Fixed it hahhaa. I will try to have the patience to cut out a couple of pieces but no garantees. Im over this thing in my fron yard. Your all welcome to come cut off what you need.
