Randy's 93
Rwies
Bronco Info: 93 Bronco
Randy's 93
Post by Rwies »
Ok after a few months of collecting parts it is finally time to start a build thread.
Day 1
Rwies
Re: Randy's 93
Post by Rwies »
Bumper build
24-70mm L Series Lens 094.jpg (211.15 KiB) Viewed 4650 times
Rwies
Re: Randy's 93
Post by Rwies »
This weekends chores are to install:
1. Solo C&T beams & radius arms
2. King Coilovers
3. Solo shock tower/engine cage
I should have the suspension on this weekend, ordered the coilovers today and should be ready friday.
Re: Randy's 93
Looking good!
Rwies
Re: Randy's 93
Post by Rwies »
Thanks Nick...I should be posting more pictures of the build after this weekend once the "face lift" is all complete.
Re: Randy's 93
Rwies wrote:Thanks Nick...I should be posting more pictures of the build after this weekend once the "face lift" is all complete.
Looking forward to the pics!
Brad12
Bronco Info: STOLEN 1994 XLT, 6 in. Superlift, ext. RAs, 35X12.5 R15, TTB, 8.8, 351, 3.55, K&N
Re: Randy's 93
Post by Brad12 »
I keep checking this thread hoping to see pictures of the install. Did you ever get around to it? Pics?
USA
Rwies
Re: Randy's 93
Post by Rwies »
Well its been a slow go...I had alot come up the last couple weeks. Right now I have the beams and radius arms on and just started removing the factory coil buckets. King just finished my coilovers so im picking them up tomorrow on my lunch break. I have a few pictures I can upload tomorrow! Im hoping to have it finished within the next 2 weeks...we shall see
Rwies
Re: Randy's 93
Post by Rwies »
Just picked up the shocks at lunch! Pictures to come 8-)
Rwies
Re: Randy's 93
Post by Rwies »
A few update pics
Rwies
Re: Randy's 93
Post by Rwies »
I got the tower installed over the weekend, it was a pretty straight forward install.
Still on the to do list:
1. Finish the brake lines (removed ABS)
2. Limit Straps
3. Bump stops
Hoping to have pictures up in the next couple days
Rwies
Re: Randy's 93
Post by Rwies »
Finished the bumps and limit straps last weekend...More pictures to come
Re: Randy's 93
Awesome... how about a far back pic!
Re: Randy's 93
She's coming together!
The bump stop seems really low... are you limiting a lot of bump travel? Does it bump on the radius arm?
Re: Randy's 93
SteveG wrote:The bump stop seems really low... are you limiting a lot of bump travel? Does it bump on the radius arm?
Looks low to Me too. I set My hydraulic bumps up so that the beam was almost touching the frame on full bump. If you have moved the wheels forward slightly, there is no need to move anything........
Rwies
Re: Randy's 93
Post by Rwies »
Yes it bumps on the radius arm...I tried getting the most bump without binding the shock. Strapped at 15.5" travel. I was told that those rubber bumps will compress about 1.5"
Rwies
Re: Randy's 93
Post by Rwies »
A few more shots
Re: Randy's 93
Looks great.... couple of questions
1) What happened to the spare tire carrier and the holes more importantly?
2) What size tires are you running, 33s?
3) What are you doing in the rear for suspension?
Rwies
Re: Randy's 93
Post by Rwies »
tcm glx wrote:Looks great.... couple of questions
1. I removed the spare tire carrier and welded up the holes
2. Yes those are 33's I plan on stepping up to 35's once these tires are worn out
3. I will be running solo's shackle/relocater and f53's...I would like to run a 12" king tripple bypass as well but will be a while $$$$$ haha. For the time being i am running a 2"block and bilstein 5100's.
Re: Randy's 93
The tailgate looks great without the factory panel! How much of the rear did you have repainted?
