- BajaF250
- Bronco Info: 1982 Ford F250
Re: BajaF250
Ok, you guys are getting a little carried away... I wouldn't dare use a yellow bubble shield with the minty green helmet... it would just plain clash! So, I'd have to go clear all the way!
- BajaF250
Re: BajaF250
Post Baja mil cleanup... also doing just a little deeper cleaning cause it's time to break down the front end... much easier to handle parts clean than with Baja dirt, grease and oil covering everything! The shell is off so I can fit the new one... but it's not going into fitment till the front is done...
Now if I can just get this darn house project done I can really get started on the real important project!
- 2013-11-25 14.58.44.jpg (227.96 KiB) Viewed 7306 times
- 2013-11-25 14.58.55.jpg (229.68 KiB) Viewed 7306 times
- ESHALLBETTER
Re: BajaF250
Looks good Tom!
Re: BajaF250
As always!ESHALLBETTER wrote:Looks good Tom!
- BajaF250
Re: BajaF250
Thanks guys!SteveG wrote:As always!
Re: BajaF250
Hey Tom, meant to ask, what's with the new shell??
Re: BajaF250
The new shell has fold-out wings and rockets boosters, so it really will be "The Minty Green Flying Machine".
- BajaF250
Re: BajaF250
tcm glx wrote:Hey Tom, meant to ask, what's with the new shell??
Experimenting... I'm going to put a forced air tranny cooler up under the rear cage and I'm thinking about cutting an exhaust hole in the top. Not 100% on design or even if I'm going to do any cutting... not sure I need it. But, I'm going with a cutout front (where the front window would normally be... I'm going to cut it all out and leave it open. It has no windows on the side, so if I do decide to open the sides up, I can cut it out to my own perameters... and then use stainless hardware cloth to secure it... sort of like Bill's gray bronco. Plus, I'm not running a tailgate or rear window. So, this will be the "unsecure" mode."AussieRod wrote:The new shell has fold-out wings and rockets boosters, so it really will be "The Minty Green Flying Machine".
It's not a "new" shell, it's well used... got it off of craigslist for $100 and the fiberglass is solid and it's made nicely. Right now, it's red! So, once it's cut out, mounted and configured the way I want it... I'll have it painted to match. You'll never know the difference!
- BajaF250
Re: BajaF250
Hey Steve,ChaseTruck754 wrote:Nice!
Still interested in the current front end if you decide to give up your "spares"
Ok, not sure what I'm going to do with the old setup quite yet... but I'm gonna keep it around until the new front end is tried and tested... Not quite sure what you'd want with the old setup though... it won't fit anything other than a 80-97 ¾-ton... you gonna build one?????
Re: BajaF250
The second half of your question might be answered in the long distant future... Which leads me to the 1st part of your post = I'm in no rush. I've got enough on my plate currently
I've had an idea kicking around in my head for a while that I'd love to get to some day soon, but I've got a bunch of other stuff to get running 1st. Having beams to work with would just save me some time on my next project, so if I can snag yours, with how nicely you did them, I'd be way ahead when the time came.
- Bronco Info: 1977 ford 4wd mountain truck, 1970 ford crewcab 4wd being built. autofab parts also.
Re: BajaF250
My question is dana 50 or 44 TTB. Love your truck! Looking to do a truck and 2 chasis f250 4wd or f150 4wd. Gonna go with older cab, love the older style trucks. Why dana 50 frt end. I know the dana 50 ring and pinion is a little stronger and can possibly take a little more shock load? Looking to do a dana 50 with extending arms for little wider stance. looking at 35" or 37" tires. Gathering up parts and will be building. Finishing up another project currently. thanks for any input. lost in wyoming and loving it!
Re: BajaF250
Toms truck has a Dana 44HD front end.
Re: BajaF250
thanks philofab on this information. Was looking and wondering exactly what he had. Will be building something similar but older body style!
Re: BajaF250
keeping old iron alive one ford at a time!
- 1780880_543236512449928_1652278189_n.jpg (18.62 KiB) Viewed 7008 times
Re: BajaF250
seen this 78 ford 2wd and think baja 250 has inspired me to build something similar but 4wd. Not sure who built this truck but love this 78ford. Baja 250 has givin me big ideas and this is the direction i will be going. thanks from wyoming!
Re: BajaF250
That blue Ford is so cool. One thing to remember -- a 78 here in AZ has a much different emissions requirement than the 79!
- 1Hondalover
Re: BajaF250
What's happening here Tom?BajaF250 wrote:Now if I can just get this darn house project done I can really get started on the real important project!
- flyinbronco
- HuckMASTER
Re: BajaF250
Yeah. What's happening here Tom?
Re: BajaF250
He traded Minty for a golf cart. Pictures to come.flyinbronco wrote:Yeah. What's happening here Tom?
Re: BajaF250
Post up! Golf cart pics are still better than radio silence
