Philo's 93 Bronco aka "Lucky Bronco #3"
Re: Philo's 93 Bronco aka "Lucky Bronco #3"
Why you gotta pull the race card yo?
- ESHALLBETTER
Afortunado cabello numero tres
Totti
- Bronco Info: 89 Bronco one piece front end and rear panels, coilovers..Its still a work in process
"El diablo borracho" is the right way to say it..philofab wrote:What is a better name for this thing than #3?
El diablo borracho?
or
El borracho diablo?
Seems fitting to me....
[/COLOR]
Springs showed up today from PAC!
I like GOLD!
I like GOLD!
Looking good. I count 6 there - how many did you have done? You are using these on the bumpside too - right?
I did 8 for now. Still have some powder left...
That looks like tge gold they use on the subaru wheels
you doing the coating in house now philo? I've had a gun for years & powder here, even had a small oven while i had my shop & I never got around to trying it. Oven was often too small for anything I wanted to do.
No, I had Messer / Allcoat in Kingman do them. I just bought the powder myself since they don't carry this color.ChaseTruck754 wrote:you doing the coating in house now philo? I've had a gun for years & powder here, even had a small oven while i had my shop & I never got around to trying it. Oven was often too small for anything I wanted to do.
Worked on installing the uniball cups today. Got one done other than welding. I need to fit it up and cycle it before welding. The beams needs cleaning up around the hole and a small chamfer too.
Before you weld that in you may want to make a solid spud the same diameter as the uniball and insert it into the uniball cup to both help prevent distortion, wick heat away and keep the ID clean of flying slag berries.
They sell em but there way overpriced. I'm sure you have access to a lathe but if not I can make you one.
I usually wipe the inside of the cup with brake fluid to stop anything from sticking. As far as distortion goes I have never had a problem welding without an insert.Rmc wrote:Before you weld that in you may want to make a solid spud the same diameter as the uniball and insert it into the uniball cup to both help prevent distortion, wick heat away and keep the ID clean of flying slag berries.
Nothing a press won't overcome.
I was actually thinking about building a AGM like tool to press them in/remove them. Lots easier than dragging the whole beam to the press.Rmc wrote:Nothing a press won't overcome.
Some power steering parts came in today.
I am going to redo my Sag pump with a external res (easier filling, it has to be done through the fender well now and won't be possible when the panels are in), filter, cooler on the engine cage cross bar, Tommy Lee GMT800 box with a 12/16:1 variable ratio, ram assist, and a 1.5:1 quickener.
More power steering parts.
Is that from PSC?
Ordered from Tommy T at Poly. The box had Power Steering Warehouse on the return label.yikes wrote:Is that from PSC?
Brackets are here... time to mock up brakes. The big plate is to mount a winch on my trailer, and the teardrops I just like to have around to terminate a tube.
