1990 go fast bronco “Eddie “
xjgiles_
Bronco Info: 1996 lariat bronco
Re: 1990 go fast bronco “Eddie “
Post by xjgiles_ »
ntsqd wrote: ↑
Fri Jun 03, 2022 2:07 pm
I saw the SwitchPro and had assumed it was more for lights and that sort of thing. It was the lone toggle and the push-button in the panel that triggered my post.
Right on those are strictly for starting it that’s it
ntsqd
Post by ntsqd »
So toggle to "arm" the push-button?
xjgiles_
Post by xjgiles_ »
Worked on the bronco some this weekend. Fighting out the location for my second steering swinger made mounts for the radiator picking away at it a little here and there
xjgiles_
Post by xjgiles_ »
Got some time to work on this again now that my vacation is over and ribs have healed. I made my brackets for my double swing steering and I’m going to start on the wiring. I also rolled it out side to wash it
xjgiles_
Post by xjgiles_ »
Had some time to work on this lately. Between helping my dad coyote swap his early bronco and other projects. It pulls 18” of travel up front 60% up travel 40% down on the 12” coil overs bump stops are tacked in need to make some more plates for the drivers side and finish weld them it’s close to final ride height I might lower it some yet we will see. I still need to do the limit straps yet. I plan to work on the fuel cell and rear shocks next. Image
Looking good
xjgiles_
Post by xjgiles_ »
hobbyturnedobsession wrote:Looking good
Thanks hopefully I can get more work done on it soon but I will see August seems to be my busy month lol something every weekend including my wife and I’s 10 year anniversary.
xjgiles_
Post by xjgiles_ »
Finally got a chance to work on this with no distractions this weekend. My patents was out of town so I got it on the hoist in my dads shop.
I started working on a pitman arm cut out a plate with the plasma put a bend in it and got a rough shape started. It works but needs some more bend to it. I had my son cut out some plates with the plasma cutter for the bump stops up front to get those done. Then I mounted my front and rear limit straps. I also mounted my steering quickner. From center it is 1/2 turn to full lock each direction. Image
xjgiles_
Post by xjgiles_ »
I have been working on getting my barn emptied out and cleaned up for the winter. And it’s just about there so I decided to bring this home to my shop. It will make it easier to work on at home. Plan is to knock out the wiring at home. I will also do some more cage and sheet metal work on it here.Image
Nice!
xjgiles_
Post by xjgiles_ »
Nick wrote:Nice!
Thanks. I haven’t done much to this it’s hunting season right now so been sitting it a tree a lot lol but soon it will be over and I can get to work on this thing. I have it in my barn and readyImage
What part of the world do you call home?
xjgiles_
Post by xjgiles_ »
I’m in michigan.
xjgiles_
Post by xjgiles_ »
A couple updates.. I been collecting more parts and have decided the 460 is going. I have acquired a coyote so I’m on the hunt for a few more things to go that route. I need a trans and t case as well as a wire harness. I have also picked up some new 35” bfg a/t’s cheap. Full set of 5. So the current tires and wheels are up for sale.Image
xjgiles_
Post by xjgiles_ »
My race line wheels showed up yesterday so I took the opportunity to teach my boy to use my tire machine Image
xjgiles_
Post by xjgiles_ »
Some progress is better than no progress right? Lol I started routing my brake lines. That’s all. I been busy my grandpa just passed and I have been dealing with that and I started working on the original black one for my wife to drive in the summer. Along with my tow rig camper and Harley. This has taken the back burner for a while.
I need to get the coyote power plant stuffed in it with the trans then I will start working on it a lot again probably around August
xjgiles_
Post by xjgiles_ »
Hopefully I will be getting back to work on this soon. Looks like I will be pulling the q80’s and linking it. I want to do it once and be done. I’m taking my time and enjoying the process. Right now I will start getting a parts list and watching market place ect for deals. In the meantime I hope to start fitting the coyote and 6r80 in the frame rails.
xjgiles_
Post by xjgiles_ »
Ordered some coyote motor mounts and some link mounts for the rear. And a few other parts. Hopefully have a nice pile of parts soon. Hopefully they will all be here so when I get the pins out of my hand. I can work on it.Image
Nice! With it being dual overhead cam is it a tight squeeze? Are you going to use the stock transfer case?
xjgiles_
Post by xjgiles_ »
I’m not sure yet. I do plan on pushing the engine back in the chassis and cutting the firewall as it will get stretched
