No good progress pictures other than this shot i took while driving it around the court to turn it around in the driveway.
Dash spreader, roof spreader, windshield /\, and the 3 roof tubes are all in. Everything is extremely tucked. Cut the additional layers out of the back of the cab roof even. Going to have to modify the shell seal. Big PITA but happy with how tucked away all tubes are so far. Maximum head room as possible as my 6' 10" dad and 6' 8" brother will likely be driving it quite a bit chasing for me.
I disassembled the dash and did a lot of mock-up. There's no way to run a dash tube while keeping the entire black section of the dash (a/c / heat ducts), so i threw the entire black section in the garbage, and am left with the factory dash "shell". I tucked the dash bar just under the dash mounting lip under the windshield.
The dash shell will be mounted off those tabs, along with several other mounts off the cage. I will build shrouds for the heat/a/c box and run my own ducts. Mounting the steering column off the cage as well.
Then pulled another dash as i cut up the one i had for the mock-up. second dash will have cleaner cuts. Pieced all the best parts from the two dash's to make a decent dash.
Then i headed to the junkyard with high hopes of finding clean carpet, and scored big. Found a bronco that actually had nice carpet, and snagged it along with many other parts. Full interior will be going back in.
Investigated the 351w running rough, hesitation and blowing smoke... may need a new 351w.
Checked the gears. 3.55. Scrapping the 8.8 and building a 9" now.
Will be taking the bronco to Fallon NV to pre-run and chase for a couple buddies racing the VORRA desert race, labor day weekend. Sure have a long to-do list though!!!
