Michael Cox's Street Queen
big-d
Bronco Info: 1987 F150, 351W/418 Stroker, E4OD, F250 1356 W/fixed yokes, Sterling 10.25, D50 TTB 4" over
Re: Michael Cox's Street Queen
Post by big-d »
This is going to be good! I love how you have built your bronco so far. Have you figured out how you are adapting the 1356 to the 4l80E? Probably 6 or 7 years ago I saw a purple ex cab Silverado built by Flying Dutchman (I believe that was the company) at one of the Whiplash races in Wickenburg. It was a very well built 4x4 Pre Runner, with a D44 TTB front end. It was using the chevy driver side drop transfer case. I never got any pictures of it and have not seen or heard of it since.
Smart Alex
Post by Smart Alex »
The 1356 t case has the same bolt pattern as a 205 t case. So using a adapter to bolt them together there and then a custom made output shaft. Which is basically th400 trans side and c6(e40d) on t case side
The case is clocked different between Chevy and Ford.
Smart Alex
What do you know about this clocking off the top of your head philo? A degree, a couple?
30 degrees off if I remember correctly. One of the bolts is offset from the BC a little too...
philofab wrote:30 degrees off if I remember correctly. One of the bolts is offset from the BC a little too...
I was under the impression that the Chev 205 is RH drop and the Ford 205 is LH drop and they are mirror image and cant be rotated for opposite drop service? :? Educate me.
I was referring to late model Chevy LH drop stuff which the 4L80 would have been attached to.
Smart Alex wrote:#limonite
Wtf, I drive by this almost everyday and always am tempted to do this haha.
Smart Alex
So philo I'm not following anymore. Your saying the clocking is different, way different cause a 205 late model ford, to a late model chevy is way off from a 1356? I'm confusing myself...
Smart Alex
Haha do it!!!! Its defiantly a huck... Lol I drive past it everyday too.. One sunday my girlfriend and I were going to breakfast and I thought it would be a good idea to jump it.
C6 adapter on left, Turbo 350 on right.
Clocking. 205 didn't come in anything modern. Doesn't matter anyway because he wants to put a 1356 on the 4L80. If you try to put the wrong t-case on it ends up at a weird angle. GM was passenger drop up to 1988, after that they went driver like Ford has always been.
Notice that the Ford uses a dowel pin to locate the T-case one way. GM uses a slightly offset bolt at the bottom. If you look closely the very bottom to the bolt is slightly right in the picture. Same bolt circle on both patterns.
otter
Post by otter »
What spring rates are you running in the rear?
drewbee88
Post by drewbee88 »
you need this bad boy:
The ST6-i Trophy Truck version features six close ratio forward gears and a heavy duty drop gear set to reduce the overall final drive ratio, enabling the use of taller (and stronger) ring and pinion ratios. The ST6-i features two possible heights for power input, clutch and converter options, plus a wide selection of drop gears that allow the ST6-i to be easily tailored to your specific application.
otter
Post by otter »
ST6-i Trans starts at $22,500 USD
Sounds like a great budget option!
drewbee88
Post by drewbee88 »
otter wrote:ST6-i Trans starts at $22,500 USD
i found one in the uk for $22,261
otter
Post by otter »
22,261 pounds
drewbee88
Post by drewbee88 »
otter wrote:22,261 pounds
Well maybe one will just so happen to fall off Robby Gordon's 77 this weekend and I will graciously clear the track of the obstacle
Now that's lemonade! Good stuff Drew.
