Bilstein 9100 and 9300 for sale
baja-chris
Post by baja-chris »
12" 9100 series 4-tube bypass shocks (2.5"), retail is $927 ea. $800/pr.
14" 9100 series coilover with dual rate kit (2.5"), retail is $567 each. $450/pr.
16" 9100 series coilover with dual rate kit (2.5"), retail is $567 each, $450/pr.
18" 9300 series Blackhawk 4-tube bypass (3.0"), retail is $2950 each. These are Blackwahk prototypes with steel cans instead of aluminum but same pistons, resevoirs, bypass valves). $1500/pr.
4" air bumps (2"), retail is $170 ea. $200/pr or free if you buy all the shocks.
PM if interested.
baja-chris
Re: Bilstein 9100 and 9300 for sale
Why is there no edit on the website? Blackwahk is kinda like Blackhawk if you are a dyslexic typist.
Smokin deal Chris.... you going King or Fox on the bronco?
baja-chris
tcm glx wrote:Smokin deal Chris.... you going King or Fox on the bronco?
Truck ended up much heavier than expected so need stiffer springs and bigger shocks.
Going with Fox all around. 4.0+2.5 in rear and 3.5+2.5 in front.
That's more shock that my last two class 8 trucks had.
The Bilstein package I'm taking off is more shock than my play bronco has.
Will make for a great setup for someone.
RNR Baja
Bronco Info: Black 94 for chasing
Post by RNR Baja »
Chris, where are you located? I am interested in the 14" coilovers
Damn Chris.... You're either a month late or a month early..... Too close to holiday for me.... Damn you. Ha ha
These will sell quick...
Il hop second in line for those coil overs(14")
Mojo
Post by Mojo »
I'll jump into 3rd spot on those 14" coilovers, cause you never know!!!
Mojo
Post by Mojo »
I'll take the 12" bypass's?
RNR Baja
Post by RNR Baja »
Still interested in the coil overs
Sent you a PM Chris
Thanks
jonnyamerica
Bronco Info: 1994 white XL Bronco
Post by jonnyamerica »
I would like to throw my hat in the ring for both the 16'' coilovers and the 18'' bypasses. sending PM now
baja-chris
All of them gone now. I gave preference to guys who wanted more than one pair to make a complete setup for one end of the car. Thanks for all the inquiries.
Mojo
Post by Mojo »
Thanks Chris :)
jonnyamerica
Muchos gracias Chris! One step closer on the build.
