Little bits of everything - alcoas, 35" BFGs, race c6, Fox
Since the supercab sold without any of this I've got some selling to do...
Autofab 3" flare bedsides for 73-79 trucks (used). These are in good shape but need to be cleaned as they are dusty from sitting in the shop - $550. New price on these is $800!
Autofab 4" lift for front (5 lug spindles) - $750
351w bare block - $50
Giant/Deaver spring under 64" leafs with ruff stuff leaf mounts, BMS shackles & heavy duty chevy hangers with weld washers. Have template of mounting position for F series.
Leafs on truck for mock up only & never run - $1,200
5 Alcoa wheels - 3 wheels are 15x7 & 2 are 15x8. These are the not so common, 8 hole design. - $500
1 of the 15x7's has some slight curb/rock rash - it's small - see pics.
I'd prefer to sell as a set, but if they don't sell after a month or so I'll separate.
6 Alcoas wheels - 5 wheels are 15" & 1 is 16" wheel. These are the 5 spoke we all know & love! I've held off selling these for a long time, with a lot of people asking but my storage is going by by so they can leave (though not without a little sticker shock ) - $900
3 have the 35" BFGs on them currently. So will do the wheels with tires for $1500
4 - 35x12.5r15 BFG ATs at 85% or so tread - $700.
3 are mounted on the 5 spoke alcoas at this time so will do the wheels with tires for $1500
Culhane built, race c6 (protruck trans - FRESH!) with gearvendor & brand new art carr shifter (set up correctly on trans by Culhane) - $2,250
Will possibly sell without GV if you pay culhane to take it off. I have the 2wd short shaft, fixed yoke or the 4wd tailshaft and housing to do so.
Radius arm mounts for heimed radius arms. Used & were welded on & cut off cleanly - $35
14" stroke, 2.0 Fox shocks - $300
Re: Little bits of everything - alcoas, 35" BFGs, race c6, Fox
Realized I forgot to mention all the alcoas are 5x5.5 lug pattern
- Becks_Bronco
Damn, would have loved to have those 5 spoke alcoa's. but i'm 5x4.5
- Becks_Bronco
Steve, do you know what the model is on those Alcoa's?
If the trans sells separate from the GV unit & it'll work ins C4, I might be interested.
Sorry Will but I don't.
And Steve - did you mean if "it'll work instead of a c4"??? Not quite sure what you meant.
c6 is a "small block" bellhousing = windsor family & cleveland.
It's the "heavy duty" bellhousing with the ribs on it.
It's got a manual valve body in it.
I think Steve meant if the GV unit can fit the C4, with appropriate adapters.
If u take off the gear vendors how is the output shaft coupled? Is it a super long output shaft? Wondering cause I need a fixed tail shaft for my unfinished 1400 truck.
Clarification: fixed tail shaft to put a 1350 bolt on yoke.
I was under the impression the trans would have to be tore completely down to swap between shaft types. Please correct me if I heard wrong, if its not that big of a deal to change over ( with the gv) I also may be interested.
Sorry, Steve... I was responding on my phone & didn't proofread. I meant if it will work on a C4, I'm interested. The Falcon would looove to have Overdrive.
Everything is now currently on hold as the damned buyer on the supercab just flaked. After I'd parted with the fuel cell and motor for the thing - lovely...
Hopefully a better home for it will come of it though as something is in the works.
As for the tailshaft, etc. on the thing - yes, to change from the long to short tail shaft on the things I believe the trans has to come ALL the way apart.
It cost about $200 to have culhane do this & put the GV on when I switched to it from the fixed tailshaft (which is MUCH shorter then the long, slip shaft style)
Back up top.
Supercab sold again and the guy who bought the it is having a hard time pulling the cash together for the autofab kit & bedsides he wanted with it. He said to feel free to list back up again & if they sell before he pulls the cash together so be it.
That being said all is up for grabs again.
- Polarcub
Steve is that 351 block a roller block? If it is I am interested.
Unfortunately no. You can drill & tap the older blocks like this for the dog though.
Fox shocks sold
Autofab kit sold
- 93Broncobuff
just wondering, what all is left?
Bedsides, spring under leafs (sale pending), c6, both sets alcoas & radius arm brackets.
On a side note - someone was working on friday night! Saw the bronco and you staring at my black tacoma with full glass and a bed full of crap as I sat at a light on Beach & I think Indianapolis. I tried to wave as you turned the corner & looked but wasn't sure if you saw me.
- 93Broncobuff
Hahahah ya that was me, sorry i didnt see ya waving lol i was blastin some metallica n was in the zone lol
