Flight industries fabricated knuckles and brakes
Re: Flight industries fabricated knuckles and brakes
Thanks man!
Have you weighed a set of these with 4 piston Wilwoods versus stock with stock calipers?
My little brain is doing hot laps thinking about an upcoming project........
Love the nickel finish.
I sure haven't Brian, they are pretty heavy though. Maybe about stock weight or +2 lbs over stock. Since the steering arms are hollow I saved a bit of weight but added it back with the larger caliper set. I should weigh them just for the heck of it. Thanks man.
So much want
So pretty, want to pet the knuckles
I would think the Wilwood caliper is about half the weight of the stocker with the cast in mounts. Also, after you get done gusseting in a stocker, I'm guessing yours might be lighter than a gusseted stock one.
12 bolt d44 fabricated knuckle with 12 bolt d44 snout. 1 of 13 styles available.
You making snouts now too!?
De$ertBronco
Post by De$ertBronco »
im gunna guess they are yukon 6 bolt snouts with the extra holes drilled out..
A recent set I did. Just to liven things up a bit in the good ol Gfb
cwrisley
Post by cwrisley »
Man those look great.
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Get em Chris, Lindsay said it was
cheese5.0
Bronco Info: '96 Eddie Bauer 351w
Post by cheese5.0 »
What color is that on the knuckle and hubs in that last pic?
Nickel
cheese5.0
Post by cheese5.0 »
Powdercoat or paint? Looks awesome
Its nickel plating.
It's white zinc according to his Instagram.
-shockseals.com
dtbback wrote:Nickel
Are they copper flashing them first or just strait nickle?
cheese5.0
Post by cheese5.0 »
Looks so good. Has to be expensive though
