Flight industries fabricated knuckles and brakes
Re: Flight industries fabricated knuckles and brakes
Have you weighed a set of these with 4 piston Wilwoods versus stock with stock calipers?
My little brain is doing hot laps thinking about an upcoming project........
Love the nickel finish.
I sure haven't Brian, they are pretty heavy though. Maybe about stock weight or +2 lbs over stock. Since the steering arms are hollow I saved a bit of weight but added it back with the larger caliper set. I should weigh them just for the heck of it. Thanks man.
So much want
I would think the Wilwood caliper is about half the weight of the stocker with the cast in mounts. Also, after you get done gusseting in a stocker, I'm guessing yours might be lighter than a gusseted stock one.
12 bolt d44 fabricated knuckle with 12 bolt d44 snout. 1 of 13 styles available.
You making snouts now too!?
- De$ertBronco
im gunna guess they are yukon 6 bolt snouts with the extra holes drilled out..
A recent set I did. Just to liven things up a bit in the good ol Gfb
Get em Chris, Lindsay said it was
![](http://emoji.tapatalk-cdn.com/emoji108.png)
What color is that on the knuckle and hubs in that last pic?
Powdercoat or paint? Looks awesome
Its nickel plating.
It's white zinc according to his Instagram.
Are they copper flashing them first or just strait nickle?dtbback wrote:Nickel
Looks so good. Has to be expensive though
