95 f150 4x4
- steve-oh
- Bronco Info: 93 xlt,5.0 caged, extended beams work in progress
95 f150 4x4
Made a truss for the rear, order gears in the next weekend or so
- steve-oh
95 f150 4x4
Definitely be a Windsor motor for sure now picked these up at a smoking deal and couldn't pass it up, not sure if it will be a 408 or just a 357
- steve-oh
95 f150 4x4
I lengthened the axle 4.5 inches just to see the angle it went threw the beam, going to make a cut at 90 degrees from that angle and install some bent plate and plate over the whole beam, I'll post pics as I go and try to show progress, did this earlier.-
95 f150 4x4
That's a good plan but I'd tack it up and assemble everything With the knuckle etc so make sure everything is good before final welding and plating
- steve-oh
95 f150 4x4
That is definitely the plan, going to cut it with a sawzall to try to keep it as straight as possible
- steve-oh
95 f150 4x4
Got a little more done today
- steve-oh
95 f150 4x4
Pulled in a old bronco frame I've been saving for the mock up of the beams, got the drivers side set up now.
- steve-oh
95 f150 4x4
If you guys see something I'm missing let me know please, I'm trying not to have to cut the lower ball joint ear as I only want about 2-2.5 inches of lift in the front.
Re: 95 f150 4x4
Hey I am wanting the exact same thing. 2.5-3" max-- so I'm guessing the top gap is 4.5" and the bottom about 5" to give you the camber correction??
- steve-oh
95 f150 4x4
Camber correction is done at the lower ball joint, I believe you can do it the way you are describing but the diff has to be clocked then. I have the pass side beam done too already, post some pics later, I'm not looking for a lot of lift in mine, so I was hoping I wouldn't have to cut my lower ball joint ear, but it looks like I will anyways.
Re: 95 f150 4x4
Looking good!
- steve-oh
95 f150 4x4
Axles lengthened
95 f150 4x4
Is the passenger one sleeved right where the axle usually goes through the window? Might add clearance issues.
