current setup.
C&T stock width by otter
2.5 12in kings with 400/500 springs
fox bumps
passanger side seems very soft. when i make a left hand turn i even catch myself turning the wheel right after turn is done to make the front end straight again.
passanger side preload is about 1/4 turn more than drivers side.
if i put a passanger in the car the lean when i turn is even worse.
any thoughts on fixing? maybe a 450 top spring on passanger side, more preload??
passanger side ganger lean and feels softer
dcashley84
- Bronco Info: 96 bronco c&t stock width kings
eoffroader
Re: passanger side ganger lean and feels softer
How's your alignment and is it only the front
It's only on left turns when from a stop or real slow and and the throttle? Spooled?
I have the same/similar issue. Its that soft rear suspension fighting with the spool and sticky tires. It doesn't do it turning right cause the engine TQ works against it instead of adding to it. https://vimeo.com/146720024
dcashley84
It has an auto locker in rear. Alignment just done. I'm putting in a drop pitman Monday to try it out
Does it lift the tire? Is it better or worse from a stop?
dcashley84
i dont think it does but if i make a hard left turn it sure feels like the tire is about to come up.
