Installing a Solo Motorsports engine cage/coil over hoops. I had to unbolt the antilock brake controller next to the steering box. What are you guys doing with this, where is a good spot to relocate. I wouldn't mind getting rid of it, I would assume all you would need is a proportioning valve, new lines. Are there some error codes to clear if you remove it? Any kits or links for parts.
Thanks!
Engine Cage and anti-lock brakes
Texas_Baja
- Bronco Info: 1995 Bronco, White XLT 351. Building a trail / go fast truck.
- Silverslk
Re: Engine Cage and anti-lock brakes
Too lazy to search for it right now but there is a thread about removing ABS.
- economig
Agreed with what Andy said...
If you google it, there's several detailed threads with close-up pictures for "Full Size Bronco ABS delete" i would post a saved link but i'm on my mobile (sorry). Shows all the wiring with labeling, etc.
I'm probably going to delete mine and do a dual bore CNC pedal assembly with 16" swing pedal (full size) but i'm pinching pennies til i can buy it all and set it up.
I hooped my engine cage over the ABS module so that it barely clears and i can leave it if i want or not. Thought SOLO's was the same? Can't remember off top of my head though
- Silverslk
- economig
Holy awesome link info batman! Ha ha that's the one!!!
Texas_Baja
Awesome. Thanks!Silverslk wrote:http://www.gofastbroncos.com/forum/view ... =14&t=1359
- Deleted Account
I have found the the trashcan is an excellent place to keep my abs......
Mark Kiefer
Southwest Performance
858-449-2292
Pics
858-449-2292
Pics
I just removed all my abs stuff using the link posted above. It was a little over whelming on paper (I printed everything from the link out) but once i started taking stuff out it all made sence. Now if I can just finish the rest of the truck so I can drive it around and make sure it works!! HAHA
Texas_Baja
ABS Removed!! Wasn't so bad still need to install a proportioning valve. Any recommendations ? Don't need anything fancy just reliable. Thanks
