Poly bumps
78Class3
Re: Poly bumps
Post by 78Class3 »
ok cool, thanks
slawson2000
Bronco Info: '87/96... a 20+ year work in progress
Re: Poly bumps
Post by slawson2000 »
I was hoping to resurrect and get a little more information on the stops mentioned here. What are the collapsed dimensions of these, the S10, Pathfinder and Isuzu? For those of you running them, can you share your front/rear suspension and bump stop setup?
I would at least like to know where to start.
baja-chris
Re: Poly bumps
Post by baja-chris »
I finally gave up on the Pathfinder bumps after my last set broke apart in a few hundred miles. I decided it was cheaper to buy air bumps than to keep replacing the poly bumps. Was able to fit them under the bed by landing them on a pedestal off the back of the rear housing. Can get away with that because the housing is 1/4" 4130 tubing. Would never work on a production housing as the pedestal would tear a window into the housing.
Dezertbronco
Bronco Info: 1990 Bronco EB
Re: Poly bumps
Post by Dezertbronco »
I have 4 trips on my Pathfinder Bumps and love them.
slawson2000
Re: Poly bumps
Any idea on what the compressed height is? What about the S10 or Isuzu style stops?
Broke apart? I assume they got over compressed/bottomed out?
Re: Poly bumps
slawson2000 wrote:Any idea on what the compressed height is? What about the S10 or Isuzu style stops?
Something to consider, BajaChris has more baja miles on his truck than most of us combined. I think for us casual users, the poly bumps will work fine.
ntsqd
Re: Poly bumps
Post by ntsqd »
I have just short of a decade on a set of the figure 8 Nissan bumps under the rear of my '84 yota Mini Chase/Expi truck. The truck gets flogged hard, but not for the durations that a real pre-run truck sees. However it is usually carrying more of a load than a pre-runner when it does get flogged. They show abuse (like the u-bolts rubbing slots in them), but they're still going strong.
slawson2000
Re: Poly bumps
Any idea on what the compressed height is on the Pathefinder bumps? What about the S10 or Isuzu style stops?
slawson2000
Re: Poly bumps
Anyone?
Dezertbronco
Re: Poly bumps
slawson2000 wrote:Anyone?
I want to say about 1 3/4-2"
under a hard hit they can desenegrate so you could also plan for about 3/4" if you bash it hard.
I cut off the stock pathfinder mounting ears and trimmed them to fit the contour of the frame welded in a nelson stud using the stock hole with no issues.
Re: Poly bumps
Was that the answer for the Pathfinder ones or the S10 ones?
I also cut a set of the Pathfinder ones up but I was guessing at more of a 2.5" or so compressed height (of the rubber) on them.
Using them like this for the rear of my crew
Stock is on the left here & the starting of my cut ones on the right.
Dezertbronco
Re: Poly bumps
[quote="ChaseTruck754"]Was that the answer for the Pathfinder ones or the S10 ones?
I cut all the tabs and bracing off of mine down to just a flat plate. Yes Mine are pathfinder bumps..
Re: Poly bumps
baja-chris wrote:I finally gave up on the Pathfinder bumps after my last set broke apart in a few hundred miles. I decided it was cheaper to buy air bumps than to keep replacing the poly bumps. Was able to fit them under the bed by landing them on a pedestal off the back of the rear housing. Can get away with that because the housing is 1/4" 4130 tubing. Would never work on a production housing as the pedestal would tear a window into the housing.
Mounting bumps off center is hard on the springs. Unless you have a 2 link.........
Dezertbronco
Re: Poly bumps
Thats what i was thinking.
slawson2000
Re: Poly bumps
Thanks for the great info. What you you think about these off of a Chevy pickup? Anyone running them?
Re: Poly bumps
Ive got those but mine are red, been running them for 2 years now with no issue.
-shockseals.com
kylesgorter
Re: Poly bumps
Post by kylesgorter »
I have the same Chevy bumpstops on the front of my truck I made a short cup out of some scrap pipe and plate uses center bolt and the base plate is tear drop shaped and hits the front hole on the bucket. Truck is basically stock so I have felt them being used from time to time seem to absorb the.impact a lot better. I have a bunch of them at work in a box people rearely want them back when we install airbags. I put yellow superduty bumpstops in the rear the oval foam ones not the plastic kind. Got those from work too, they are about 3.25in long don't think I've touched them yet though my rear springs are burly
slawson2000
Re: Poly bumps
You made a cup? Different than the ones that come on the Chevy bump stop? Got a pic?
