Off-Road Light Beam Photos-Add yours...
Feel free to add your own.
Light info: Two OLD Rally 2000 Euro Beams and two OLD Rally 2000 Pencil beams, all with 100 watt bulbs. Powered by a 12v continuous duty solenoid which works way better and is much simpler than the two Bosch relays I used to have for them.
Photo info: Starting with the daytime photo, I set my camera to manual and adjusted the shutter timer until the scene in the photo looked the same as viewing it with the naked eye. I repeated for the night shots.
FYI: The shed in the photos is 30 yards away, the ground is not flat... slopes up to the shed.
Disclaimer: These are not 100% accurate. but they are a half-ass decent representation of the lights' performance. In other words, this post is worth exactly what you paid me for it. Also, if, as a result of this post, you have an erection that lasts over 4 hours, call someone that cares.
From this thread: http://www.gofastbroncos.com/forum/view ... 567#p74567
tcm glx wrote:Post some pics Steve.
Just for you, Tony!
Continuous duty 3-wire solenoid used to power the lights.
IMG_3219 (640x480).jpg (142.09 KiB) Viewed 1053 times
Control shot during the day.  Please ignore the random debris... in the process of cleaning out the yard.
IMG_3214 (640x480).jpg (193.73 KiB) Viewed 1053 times
Low beams.
Low beams.
IMG_3224 (640x480).jpg (109.18 KiB) Viewed 1053 times
High beams.
High beams.
IMG_3225 (640x480).jpg (139.22 KiB) Viewed 1053 times
High beams plus 2 Flood and 2 pencil beams.
IMG_3226 (640x480).jpg (164.5 KiB) Viewed 1053 times
Surefire Flashlight just for fun.
IMG_3227 (640x480).jpg (69.7 KiB) Viewed 1053 times
Re: Off-Road Light Beam Photos-Add yours...
32" LED bar. 3w Cree bulbs
low beams
w/led
Agui-E7TE
Post by Agui-E7TE »
Any comparison shots to the HID's Tony? Did the HID's pull more amps or does the LED light bar pull more.
Here's my headlights 35w hid low
Low above, high second pic
High beams plus 4 35w hid converted rally 4000
I need to bring 2 of the bumper lights up a little.
Just to add my pics to this thread to keep things together...
pic 1 is low beams
pic 2 is high beams
pic 3 is the 200w 20" light bar with CREE leds sitting on my core support...with out headlights
I found this vid to add as well...
this is 2 - 8" KC Highlites LED PODs, they have 2 17w LED chips each I believe
95bronco12
Bronco Info: 1995 bronco 5.8 4inch lift on 33's
Post by 95bronco12 »
This is mine when they were on top of the truck will try to get some now that there on the bumper.
