What is this chingadera?
95 Bronco
Mounted on the drivers side inner fender there is a silver box with about a 10 pin plug, it says motorcraft, anyone know what it is?
- ESHALLBETTER
Re: What is this chingadera?
Pic? Otherwise Philo will know.
You can see how a couple wires pulled out, I can fix it, but it's going to be pretty tough
Ignition control module. Make sure its bolted to metal or you'll have gremlins!
Dang, looks like I am fixing those wires then!
Hahah yeah unless you go to an ignition control box like mad or the like.
Can you elaborate on that?hobbyturnedobsession wrote:Hahah yeah unless you go to an ignition control box like mad or the like.
I think you meant to type MSD, if so, never mind!
Stupid autocorrect ha. My bad yes that's exactly what I meant. I've never ran one but there's a discussion somewhere on here about them
If you need to splice the wires, make sure they are sealed with best-shrink tubing. Don't give corrosion a chance to get into the wires or connector.
greaslife
with my elc. i use either a crimp and shrink or a solider and shrink. the best heat shrink has glue in it. if in dough use somthing sold a a boat shop will be weather tight
Thanks for all the help, I'm pretty OCD on wiring, so I'll make sure to do it up right.
greaslife
if your close too me and bring it buy i will do it for you
i love electrical
i love electrical
I should be able to handle it, it's definitely going to need a non insulated butt connecter
- Phoenix0783
If it's running with wires missing, I'd be surprised. That's the TFI module for the ignition.
- Agui-E7TE
I have one of those in my '89 Bronco but Its not plugged in to anything since the fender came off a newer F150. I didn't bother removing it since it can serve as a spare for anyone else who might need one out in the dirt.
Carry a spare if you do any prerunning in BFE...one of few stupid parts that will leave you stranded pretty quick.Travisfab wrote:95 Bronco
Yeah I wasnt sure if I had ripped the wires when i pulled off the fenders. I havent tried to start it since.Phoenix0783 wrote:If it's running with wires missing, I'd be surprised. That's the TFI module for the ignition.
DukeSky
- Bronco Info: 92 4" Rancho, Procomp coils, Sagswa pump, 3G alt, 95 E4OD Built w/computer, locked
go to www.rjminjectiontech.com they carry all the pins, connector bodies, etc.. for Ford. If you don't get a good connection as Phoenix states, it will haunt you like a bad case of poison oak.
- sydude
A couple of things, first:
http://www.fullsizebronco.com/forum/sho ... p?t=183668
Second,
If you've got a '95, you likely also have the wrong ignition control module installed in that heat sink. The one you have is a GRAY 'push start' type module. 94's to 96's most universally need a BLACK 'CCD type' module. Do NOT use ANY parts store's reference numbers to give you the correct part - you must refer to this thread for the only correct unit for your truck (Motorcraft - DY1077 (supercedes DY679, DY667, DY645)).Travisfab wrote:You can see how a couple wires pulled out, I can fix it, but it's going to be pretty tough
Second,
Are you sure an EEC-IV system will run without the TFI module? I thought the MSD box will run alongside the TFI but not without it.hobbyturnedobsession wrote:Hahah yeah unless you go to an ignition control box like mad or the like.
