Mounting Seats
Conejoracer
- Bronco Info: 1992 XLT 5.8, Beater
Mounting Seats
Has anyone here mounted off road seats (beard, mastercraft, etc.) to the stock Bronco Bench seat mount? If so, did you buy or fabricate the mounts for that install? I'm building my Bronco on the cheap, so I'd like to install my seats this way until I can have it properly caged.
- navynuke
- Bronco Info: 82 Bronco with some goodies
Re: Mounting Seats
I mounted some to a set of the stock bucket seat mounts, not sure about the bench mounts though.
Here are some pics to help give you an idea though, and my seats had a flat mount like the stock ones, not the 4 tabs the way most beard and mastercraft seats are setup
just drilled hoes in the passenger side where needed
full write up available here
http://www.fullsizebronco.com/forum/sho ... p?t=163987
Re: Mounting Seats
the stock brown low back pattern looks pretty bitchen. I like it.
- navynuke
Re: Mounting Seats
The back seat still matches it, but the drivers side was toast when I got the truck.
you can see the pattern of the back seat in this one
lifeinthesouth
- Bronco Info: 95 5.0L/E4OD
Re: Mounting Seats
I just have some cheapo racetrims. They look the same as navy's and i mounted them exactly the same way.
You may just look into grabbing some bucket mounts out of another bronco or truck and adapt them.
Re: Mounting Seats
I ran mine off of the stock mounts but lifted them a little. Works just fine.
Conejoracer
Re: Mounting Seats
So it looks like I'd make some simple adapters, like those show for the bucket seat base installs? That seems easy enough!
