cruise control shut off switch - Ford recall
H-rider
Bronco Info: 1996 white XLT 5.8 - ready for GFB transformation
Re: cruise control shut off switch - Ford recall
Post by H-rider »
I called the dealer and they said they would only install the pigtail and leave the switch.
I wanted to replace the switch to see if this would cure the cruise control non-working problem.
Bought the switch and pigtail from rockauto.com (Motorcraft part) for less than $10, installed in a couple minutes and CC works like it should. :D
If you think you can or think you can't...you're right!
