Body mounts.
kahuna bill
Bronco Info: auto fab lift, 90 body on 91 frame, e40d, performer heads,jba headers, K&N intake
Re: Body mounts.
Post by kahuna bill »
i'm a bit late since you got ur mouts i went and got a 3" exhust, cut it lengthwise so that i could open it and used three 1/4"x1" flat stock with a hole drilled in the center to accept the body bolts. I than used them to pull the lower body mounts down. Used my impact and PB blaster.
Re: Body mounts.
Looks like good setup. After I showed my buddy pics of the stuck drift in my earlier post he showed me a setup he had that is much like yours above. He used a big socket instead of the exhaust tubing though. It works well.
kahuna bill
Re: Body mounts.
i wish i had a socket that big... i started out with the 1/4" flat stock but bent the crap outta that, than moved up to two and again i bent those. finally after 3 1/4" stacks of flat stock they stopped bending enough for me to pull the mounts. they're frustrating little bastards.
Re: Body mounts.
Energy Suspension Poly Body Mounts
2017-03-08 05.29.12.png (557.66 KiB) Viewed 463 times
For those who have replaced the factory mounts with poly mounts, can you tell me location of the mounts circled? They have a larger register diameter and I have no idea as to which position they belong. Thanks in advance.
Re: Body mounts.
Been a loooong time since I have done these Will, but aren't those the rearmost ones? I seen to remember something having a hex shaped register, but I'm thinking that was the core support ones.
Re: Body mounts.
X2 on core support. Core support bushings dont have 2 pieces to them like the other body mounts do.
-shockseals.com
Re: Body mounts.
Thanks guys!
