snowman429's 93 Bronco v2.0
- snowman429
- Bronco Info: 93 Bronco alot of work
Well this is going to be a slow build, but thought I would start a thread. The Bronco has gone under the knife. I've started removing all the SAS stuff. Here's a couple of pics.
- uploadfromtaptalk1388290495361.jpg (56.71 KiB) Viewed 2607 times
- uploadfromtaptalk1388290483869.jpg (68.36 KiB) Viewed 2607 times
- uploadfromtaptalk1388290461968.jpg (50.73 KiB) Viewed 2607 times
- uploadfromtaptalk1388290447188.jpg (50.39 KiB) Viewed 2607 times
Re: snowman429's 93 Bronco v2.0
Are you running headers?
- snowman429
No, not yet
That's odd. The first thing I thought of is heat soak. Sometimes when running headers it'll heat up the starter
- snowman429
I'm lost
Last question. You still running the side starter relay? Sometimes new starters will require you to remove the firewall relay. If you still have the paperwork double check and make sure that it doesn't say to get rid of it
- snowman429
I think you have your post confused. I haven't asked anything about headers.hobbyturnedobsession wrote:Last question. You still running the side starter relay? Sometimes new starters will require you to remove the firewall relay. If you still have the paperwork double check and make sure that it doesn't say to get rid of it
Headers will heat up a starter to the point it won't want to kick over the motor. Not confused.
- snowman429
That's good to know but ive never posted anything about having a hard time starting my bronco.hobbyturnedobsession wrote:Headers will heat up a starter to the point it won't want to kick over the motor. Not confused.
Ah hell my bad. I was reading another post and got it mixed up.
- snowman429
Kind of figured that.
- snowman429
Well, not much has happened to the Bronco. I'm waiting on parts I ordered to show up. I did however score a 9" out of a 78 Bronco already trussed with a Detroit locker for $300.00. I'm hoping more parts show up this week.
- snowman429
Whoohoo shocks showed up today
- uploadfromtaptalk1389061693855.jpg (58.95 KiB) Viewed 2393 times
Right on!
- snowman429
I'm hoping my glass shows up this week. I talked to Dave today and he should be starting on the beams and radius arms soon.
- snowman429
Well no fiberglass this week. Apparently they shipped my order to s someone else. I ordered it on the 2nd of December and was told 2-3 weeks. When I called on the Monday before xmas they said it was going out that week. New years eve was told out was getting put on the truck that day. Called today and they said it was getting shipped today and I'll have it Monday. I'm so frustrated with them right now.
What fiberglass company
- snowman429
McNeil.
- snowman429
I didn't order a hood. I saw that right after I got off the phone with them.
