SteveG's 84-SOLD!
Re: SteveG's 84
Right on Steve! Can't stop now man.
Re: SteveG's 84
Pismo will be here quick!
Re: SteveG's 84
For sure I wil never get rid of that machine. I just have to
dig it out, I just moved a mouth or so a go and haven't given it
a thought.
a thought.
Re: SteveG's 84
Philo, I ended up just buying a reman (yuck) ECM since I could buy one that was exactly what I needed (5.8L/C6). It's easier than having to custom program one to match my trans. Thanks anyway, though.philofab wrote:I have a 93 AOD-E & an 89 M5R2 off the top of my head. I look the codes up tomorrow.
Progress is taking place. I've removed the complete EFI harness & started tidying it up... again. While it's out, I decided to add another filter. I have one at the ignition coil power lead (just as the factory does) but I decided (on my EFI guru's recommendation) to put one at the ECM as well.
Normally, I use OE connectors for just about everything but I didn't feel like digging through my totes full of harnesses to find the matching connector for the OE filter. I typically hate using insulated crimp connectors but for a non-critical connection like this, I don't mind using it. But, I do take some extra time to make sure it's not going to give me any grief later.
Crimped, soldered and ready to re-insulate. I did the same for the harness side except I added a piece of white heat-shrink tube and labeled it. No fancy connector kit required!
Re: SteveG's 84
The harness is back in. I made a couple small changes while I had it out. I relocated the MAP sensor, altered the Oxygen Sensor lead and, most exciting, relocated the speed sensor. I originally added a speed sensor at the transfer case where the speedo cable was. This required several feet of wire (no big deal but more to route, loom and secure) and a custom speedometer cable... boo! Instead, I ran the speed sensor wires to above the brake booster and left the connector right on EFI harness loom. Then (here's the exciting part!), I tapped into the cruise control speed sensor and hung a connector out of the CC harness that will plug right into the EFI harness. Simple, effective, less climbing under the vehicle and one less sensor!
Almost there.
Almost there.
- Cruise control speed sensor.
- CC Speed Sensor (640x382).jpg (160.11 KiB) Viewed 2489 times
- Speed sensor connector at harness.
- IMG_3049 (640x480).jpg (213.43 KiB) Viewed 2489 times
- Just needs some loom and tape....
- IMG_3052 (480x640).jpg (239.24 KiB) Viewed 2489 times
Re: SteveG's 84
Nice! So it'll be at pismo - right?
I'd hate to see you have to pull the wagon way out in the dunes...
Re: SteveG's 84
I will ride shotgun in the wagon...bad ass mo-sheenChaseTruck754 wrote:Nice! So it'll be at pismo - right?
Re: SteveG's 84
Don't get me wrong - I LOVE the wagon, I'd just hate to see if get buried in the sand when we make Steve take it out since he showed up without the bronco.
Re: SteveG's 84
I say we all get old cars and cruise the shit out of them. Road trips in the old stuff is great therapy.shockseals.com wrote:I will ride shotgun in the wagon...bad ass mo-sheenChaseTruck754 wrote:Nice! So it'll be at pismo - right?
Re: SteveG's 84
Sounds good! Oh wait, that's all I have is old cars.SteveG wrote:I say we all get old cars and cruise the shit out of them. Road trips in the old stuff is great therapy.shockseals.com wrote:I will ride shotgun in the wagon...bad ass mo-sheenChaseTruck754 wrote:Nice! So it'll be at pismo - right?
Re: SteveG's 84
Now all we need to do is start using them. You meeting us at Billetproof next year?300 wrote:Sounds good! Oh wait, that's all I have is old cars.
Kris, if I promise you shotgun in the wagon, does that mean you'll make it to Pismo?
Re: SteveG's 84
Good progress today. First, though, a repair that will make even the most discerning critics proud. A slight eyeball miscalculation resulted in a bit of fan/upper radiator hose contact. I was already going to get a different hose that fits better with the carb engine accessories and EFI intake but needed to drive it in the meantime. No problem. I got patches!
- Hose Patch (640x383).jpg (152.62 KiB) Viewed 2381 times
Re: SteveG's 84
So I buttoned up most of the EFI wiring today and drove the Bronco for the first time since repairing the harness. Unlike with the original ECM, the engine fired immediately and ran perfectly... woohoo! The last major EFI-related project is finding the twin air intake hoses (Throttle-bodies to air cleaner). I have a late-model air intake/cleaner to get my by for now but that won't fly with for the smog referee, so I'll need to hunt around for that.
I put about 12 miles on the truck with lots of stop and go in town. It really felt great. Lots of torque, good power at full throttle and it idles smooth. Ahhhh, EFI....
I also finally started permanently wiring in the radio. I used a junction post for battery to keep from having a bunch of battery power wires terminating at the battery cable end. I love these things. The really help clean up wiring. On a related note, I recently picked up some "marine" heat-shrink tubing at Harbor Freight. I had my doubts, but for $3.99 a box, it was definitely worth a shot. So far it works great and I'm loving having cheap adhesive-lined heat-shrink. I'll keep using the expensive stuff for critical wiring (EFI an such), but for just about everything else, heck yeah!
Here's how I usually terminate power/ground circuits that will be exposed to the elements.
Crimp uninsulated terminal and solder the end of the terminal and the seam.
Adhesive lined heat-shrink between the terminal body and wire insulation.
And finally, the gratuitous poser shot. Not bad for a 28 year old, huh?
Re: SteveG's 84
I forgot to add the photo of the junction post. Note the weather resistant fuse holder as well. I might add a small fuse box later but I have a few of these fuse holders, so I might as well use them. I still need to add loom to the cable from the battery to post for abrasion protection. I called it a night before started on the ground circuit for the radio. Maybe tomorrow.
- IMG_3066 (480x640).jpg (238.45 KiB) Viewed 2375 times
Re: SteveG's 84
Truck looks great steve awesome work. I'm so jealous I want an 84 think it'd be cool to have a truck same age as me ha.. And a 95 for the mass air non obd II. I use that harbor frieght heat shrink all the time. Holds up great so far even in saltly grimmy roads up here. I know how finicky these old electrcal systems can be. I did a mass air conversion on a 94. Took me weeks with the help of the vendor to find that an internal ground was bad in the supplied mustang ecm. Gotta be a good feeling to see light at the end of the tunnel.
Re: SteveG's 84
Thanks! You can just buy mine when I'm bored with it again... probably in a couple weeks!blueoval8493 wrote:Truck looks great steve awesome work. I'm so jealous I want an 84 think it'd be cool to have a truck same age as me ha.. And a 95 for the mass air non obd II.
Don't get too hung up on MAF. I could have easily gone mass air with my conversion but I just didn't see the point. In fact, I started with a sequential injection (necessary for MAF) and converted it to batch fire (Speed Density). The only advantage a MAF sensor gives is it can compensate for engine changes (which I won't be doing). The other advantage MAF has over Speed density is it can adjust for elevation on the fly... sounds like a big deal, but all you have to do with Speed Density is pull over and re-start the engine and it will adjust accordingly. Best of all, Speed Density does not have an expensive MAF sensor to fail.
The one major advantage the newer EFI systems do have is a grounded Oxygen Sensor. The early systems grounded the sensor through the exhaust system. It's funny that they grounded the most critical EFI sensor through the most corroded part of the vehicle. Genius, huh?
Anyway, I'm happy to almost have the conversion done. It runs great and is fun to drive again.
Good to know. I like GOOD heat-shrink tube, but for the price, this stuff is hard to beat for most projects.blueoval8493 wrote:I use that harbor frieght heat shrink all the time. Holds up great so far even in saltly grimmy roads up here.
- Agui-E7TE
Re: SteveG's 84
Nice job on getting it all running with the EFI. The reliability and smoother operation is well worth it. Also, nice work with the electrical wiring.. I wish I had the patience to properly crimp, solder and heat shrink all my connections (it's one of those habits that I have to start trying to get into).
Is the Oxygen sensor one of the things you can convert to the later style for the proper grounding?
Oh, almost forgot... Love the radiator hose patch/repair. Didn't even know that could be done. Gotta remember that one for future field repairs.
Re: SteveG's 84
Digging the progress and the CLEAN wiring. That's the way it SHOULD be done - looks good.
Re: SteveG's 84
Absolutely. The harness I started with did not use 4-wire Oxygen sensors. Adding the adding a ground to the Oxygen sensor is a piece of cake with the harness out of the car. Even with the harness in the car it wouldn't be hard to convert to a 4-wire sensor. It would just be a matter of running a ground wire to the sensor and through the connector.Agui-E7TE wrote:Is the Oxygen sensor one of the things you can convert to the later style for the proper grounding?
Thanks, Steve!
Re: SteveG's 84
I thought the four wire O2s were heated so they had an additional +12 wire? Or are you just not using the heating element?
