95 Black Bronco
Re: 95 Black Bronco
Might want to look at power steering solutions and Psc. Psc has a full kit for much less than Howe. Not real sure how high the quality is though but it's a big seller with the jeep crowd. Might be worth looking into.
- motoxscott
- Bronco Info: 408 Prerunner
Re: 95 Black Bronco
Charlie @ PSS is good .... stay away from PSC. Had some friends get their stuff and wasn't happy with the quality compared to Lee, Howe, PSS.
- Scott
- Scott
95 Black Bronco
Talked to Bobby at solo the other day, he was super helpful. Think im going to run their setup using a rebuilt ported box, Howe t/c pump, resevoir with filter, pulley and cooler.
Re: 95 Black Bronco
Can't go wrong with Howe.
Re: 95 Black Bronco
Good choice buddy.C H O wrote:Talked to Bobby at solo the other day, he was super helpful. Think im going to run their setup using a rebuilt ported box, Howe t/c pump, resevoir with filter, pulley and cooler.
Re: 95 Black Bronco
Dang dude that rear bumper is clean!! Hoping to have something similar made for mine soon
Potato.
95 Black Bronco
Some goodies!
Re: 95 Black Bronco
That center console is beautiful!!! How did you make it?
95 Black Bronco
Curt at crb built it, it is blended aluminum, same one that was in Gary's red bronco
95 Black Bronco
So tight!!!
95 Black Bronco
Put in some hours this weekend to install the new steering setup, also double sheered a pair of spindles, welded a backing plate, and put fresh ball joints in. Just need to bleed breaks and the steering
- keenanduran1
Re: 95 Black Bronco
sexxx
Re: 95 Black Bronco
Did you have the stops added in the box?
Re: 95 Black Bronco
Hey Cho,C H O wrote:Got a bunch to tubes done today, got the cage all tacked up and slid it out the back to weld an paint. Still have to to do corner gussets and window v tubes. The cage is 2" and 1.75" fully tig welded, goes through the firewall in 4 spots, fully sealed, stock dash and stock headliner. My seats should be done in a week stoked to see it taking shape!
What diameter is the A-pillar cross tube?
Re: 95 Black Bronco
What rear spring rate did you end up with? I'm looking into building a similar setup and need a good starting point for springs.
- De$ertBronco
Re: 95 Black Bronco
Bronco is for sale, someone buy this black beauty! http://www.race-dezert.com/classifieds/ ... &id=115400
