VHF "Race Radio" Antenna for OBS Ford Trucks / Broncos
Peep it:
https://www.ruggedradios.com/index.php? ... ts_id=2923
Those are awesome! I may have to order one for Carly's bronco and one for my 350.
Re: VHF "Race Radio" Antenna for OBS Ford Trucks / Broncos
That's a pretty poor place to mount an antenna performance wise. Clean, but not super useful.
1Hondalover
Post by 1Hondalover »
Very cool piece Steven. That sheet metal is fairly thin to take much torquing.....did you put some kind of backing underneath?
BDKW1 wrote: ↑
Fri Apr 17, 2020 8:24 am
True. The best place for an antenna is as high as possible with zero obstructions. Buuut, most people running radios just use them running around in a relatively close group and don't necessarily need it to have the longest possible range. Generally, those users will sacrifice range for ease of installation and, especially, drilling holes in sheet metal. That said, on Wilson, I'm using it for a backup antenna.
1Hondalover wrote: ↑
Sat Apr 18, 2020 9:45 am
It seems OK. I tweaked on it and am not really concerned. Roof panels flex as much or more and I don't know that I've ever seen one break the metal. It wouldn't be hard to put a plate under it, though.
I have repaired 2 roofs where the antenna pulled out. Both Dodges......... I usually put a backing plate on the bottom side if I can fit it. A little epoxy to bond everything together and it will last a very long time.
BDKW1 wrote: ↑
Thu May 28, 2020 4:25 pm
I like the reinforcement plate. Maybe we’ll start stamping them out and offer as an accessory.
Low-profile antenna on Wilson. You’ll have to excuse all the spider webs. Wilson’s been sitting under a canopy for a few weeks....
Hmmmmm. I might need that for Brown. I think the mount would work.
SteveG wrote: ↑
Thu May 28, 2020 8:47 pm
Somebody was making them for commercial use, I used to buy them out of the catalog. I think they were for NGP transit antennas mounted in fiberglass.
yikes wrote: ↑
Fri May 29, 2020 5:58 am
Body lines are a little different, but you're smart enough to make it work. What's going on with the brown one? I wanna see!!
