Good thread I recently tried and succeeded at on my f-150.
For those of you who have had this issue, you probably know that smog pumps are extremely expensive to replace and difficult to find. If you go to a hi flow cat, or no longer have one, you don’t need the air injection system to pass emissions.
I chose to delete mine after it seized. Initially I used a crown Vic belt which is shorter, but started having issues with throwing belts, also the belt was a little on the tighter side so I was worried about excessive wear on drive components, so I tried this and it worked very well.
http://www.fullsizebronco.com/forum/7-1 ... ics/440961
If anyone has questions feel free to hit me up
Smog Pump Bypass
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Smog Pump Bypass
- Bronco Info: 1993 XLT 351. Currently being built. Solo c&t beams, solo radius arms, solo shock hoops
Re: Smog Pump Bypass
I just tried to order these parts from amazon but it won't let me ship to my CA address because of the air pump bypass Stupid california!!!
- S00TLYFE
Smog Pump Bypass
Order it through summit, that’s what I had to do
Text me if you have any questions
714 262 3674
714 262 3674
eBay let me order it.
