Here’s a link to the build thread, and I have hundreds of pictures documenting the build:
http://www.dezertrangers.com/vb/threads ... eper-Build
Asking price is $27,500. Email at nubreed71@gmail.com or text at 760.593.7692.
See below for a detailed list of specs:
Front Suspension:
* Camburg 4.5” extended beams w/ heim radius arms, and uniball knuckles w/ 2.25” race hubs
* Fox 2.5” x 12” coilovers with DSC adjustable reservoirs w/ Hypercoil springs, and AGM machined sliders
* Bolt on coilover towers with optional secondary shock mount and engine cross brace
* 2” Fox air bumps
* Dual limit straps with adjustable clevis
* Richer Racing single swing steering
Rear Suspension:
* Richer Racing 64” spring under leaf springs, hangers, and shackles
* Fox 3.0” x 11.5” 3 tube bypass shocks with QAB bypass adjusters
* Dual limit straps
Wheels/Tires:
* (5) BF Goodrich KO2 37x12.5x17 tires
* (5) 17”x8” BTR beadlock wheels
Brakes:
* Wilwood 4 piston calipers and 13” rotors at all four corners
Powertrain:
* 5.0L 302 with 113k miles. K&N intake, JBA headers, Flowmaster muffler with turn down. Autofab motor mounts.
* AOD-E transmission with 2 trans coolers (OEM + Hayden trans cooler) plumbed in, Broader Performance valve body, and Mag-Hytec transmission pan. Autofab trans mount.
* VSS relocation kit
* Camburg full floater rearend with 2.25” hubs. 5.13 Motiv gears with Strange case, billet pinion support, and 35 spline Detroit locker
Body:
* Autofab fiberglass hood, 5” front fenders, and 6” bedsides. Fuel filler door glassed in to bedsides, and custom extended filler neck. Fenders, hood and dedsides are painted with PPG Ford Oxford White, and Linex’ed on the backside to prevent spider cracks.
* Autofab A-pillar body mount outriggers for bushing mounted cage.
* Richer Racing front fender inner tube structures with custom tin wheel wells.
* Bed is 100% Linex’ed, on all surfaces top and bottom. Quart crates, jerry can mount, and race jack/mount. Flat mount spare tire.
* Custom bedrail straps with integrated tie down points.
* Richer Racing bolt on front bumper with removable light rack, as well as a removable vanity plate to cover the gap between the main tube and the lower portion of the grille.
* Richer Racing bolt on rear bumper with drop down license plate/hidden hitch, and flush mount LED reverse lights.
Lighting:
* (6) Baja Designs XL series lights up front. 4 XL80’s (amber and clear), and 2 XL Pro spot pattern.
* Baja Designs Squadron Pro rear facing amber dust light
* (2) Baja Designs Squadron Pro flush mount reverse lights
* Custom labeled switch panel built in to stock dash.
* Baja HID projector retrofitted headlights with 55w Ballasts
* Baja HID LED retrofitted taillights
* LED retrofitted third brake light with Baja Designs Rock Light cargo light
* Baja Designs Rock Light under hood light w/ switch
* All other exterior and interior lights converted to LED
Interior:
* Pioneer CD/Bluetooth head unit w/ aftermarket front and rear speakers, and powered subwoofer.
* Motorola 110w race radio
* Mastercraft Baja RS recliner seats on stock sliders - gray tweed with gray vinyl backs
* Custom upholstered headliner and visors in gray tweed to match the Mastercraft seats
* Coverlay door panels with custom upholstered gray tweed panels
* Solo Motorsports door handle reinforcement plates
* FatMat on the cab floor, roof, and doors, and mass loaded vinyl inside the door panels.
* Sparco suede steering wheel
Other Mods:
* Saginaw power steering pump & Solo Motorsports ported steering box (can add ram assist later with this box)
* 38 gallon OEM fuel tank with extended fuel pump (+ spare extended fuel pump assembly)
* Hella Supertone horns
* Ruffstuff bolt in battery box with Kicker battery terminals
* Water temp + trans temp senders installed + gauges included, just need to wire/mount gauges
* Multiple anti-theft devices that I will demonstrate to the buyer
