AC Diagram
rdcjuanb
AC Diagram
Post by rdcjuanb »
My AC isn't working under load, research has told me this is a vacuum leak in the system. I found a small hose tucked by my battery that must have come off and someone stashed(stereo shop). I need to figure out where it goes as I am hoping it may fix my problem.
rdcjuanb
Re: AC Diagram
Post by rdcjuanb »
I have a 1995 5.8l
Re: AC Diagram
Just a guess but this is pretty common- look at the pass rear fender -firewall intersection area. Look for a white plastic hose- you should be able to get back under the loom and find a good spot- just cut out and put flexible vac hose.
Re: AC Diagram
I have also plugged these before until I find the correct location it has worked for me in the past....it worth a go
LvSteve
Re: AC Diagram
Post by LvSteve »
This will help, A link to Ford sevive manual
https://l.facebook.com/l.php?u=https%3A ... Zv-vVEp6Sg
LvSteve
Re: AC Diagram
Post by LvSteve »
If the Link will not work for you let me know
Needles929
Bronco Info: 95 Part Deux
Re: AC Diagram
Post by Needles929 »
Mine is doing the same thing and I think that I have it figured out.
I barely touched this vacuum hose and it broke right off. The left side of the "T" in the picture, hose runs into the wire loom that goes to the firewall.
AC edit 1.JPG (51.36 KiB) Viewed 2026 times
There is another black vacuum hose that comes out of the same wire loom and goes here.
AC edit 2.JPG (41.69 KiB) Viewed 2026 times
I will fix it tonight after work and report back if it works.
Needles929
AC Diagram
Fixed! Replaced the line from the junk yard and wah-lah!
A/C is Ice cold and blows out the proper vents at all times. Make sure to replace or use a new one way valve as the original may not work correctly. I learned that today.
LvSteve
Re: AC Diagram
Post by LvSteve »
Hope the service manuals helped, Anybody needs Ford service manuals links ?
rdcjuanb
Re: AC Diagram
Post by rdcjuanb »
Gonna mess with this soon. I’ll report back. Thank you everyone
Needles929
Re: AC Diagram
rdcjuanb wrote:Gonna mess with this soon. I’ll report back. Thank you everyone
Again, don't forget to check or replace the plastic "T" one way valve. It almost had me chasing the problem further than needed. Good luck man!!
