Which came first, chicken or the egg (coil over/ bypass )
- apache41
- Bronco Info: 1995 Ford Bronco Solo Coilover front, Deaver Rear with Solo under bed shock bracket and hanger relo
Ok, looking at all the cool photos I see it both ways. With an engine/shock hoop mount like Solo's engine cage which shock should be mounted up front ? And Why ?
Re: Which came first, chicken or the egg (coil over/ bypass )
The bypass is placed in the position with the longest stroke between the two shocks
My set up is 14" c/o behind beam so later i can run a 16" bp in front that is also how tanks bronco is set up and worked great
