Rex , White (OJ bronco) build!
- Bronco Info: 1992 bronco, 400hp stroked 302, built transmissions, custom rear bumber, 5/8 studs
Hello
I'm building a 1992 Bronco pre-runner (in a past life I had a fully built 91 F-150, but I rolled it...)
Bought his off a guy in LA w/ (don't ask paid to much)
- Stroked 302, Comp cam, scorpion roller rockers, edelbrock 3881 intake, Y-pipe, scat bottom end, KN cold air intake, AL heads
- Also drilled the front/rear for 5/8 studs and mounted my freshly powder coated methods with 35 Bfgs
- I also built this bumper with a swing down tire carrier (not done yet)
Nice !! Welcome
Re: Rex , White (OJ bronco) build!
Nice work on the bumper. Can't wait to see it come together
I like that bumper, looks killer.
Ok couple of updates
1. got my Baja RS mounted up complete with seat heater
2. Finally got the rear bumper mounted up, had to adjust the vertical height like 3 times to get it right
3. Here area couple of shots of the latches (same set up as a car door)
4. Couple of shots of my stroked 302
Next up, need to finish the tire carrier (but wanted to bolt it up for motivation) after that extended beams!
Sorry one more thing. I CADed up a bronco frame from the attached PIC. Maybe you can use it, no guarantees on accruacy
Bumper is looking good.
What is the hex welded in the end cap of the bumper there for?
Thanks man, the hex is for holding the torsion bar. The other end hooks into the tire carrier and will reduce the force needed to pull it up.
Well thought out - I like it!
Finally got this bumper done, if I did it again I would bring the bottom up a bit more
Also add a MPI steering wheel, these are the PNs I used from summit, I was able to keep the cruise control by using the stock ford slip ring
https://www.kartek.com/parts/mpi-14-355 ... wheel.html
https://www.summitracing.com/parts/grt-5275
https://www.summitracing.com/parts/grt-4009 (this guy was of poor quality I had to drill out my wheel to get all the bolts in)
Also pulled a front end from the junkyard, gonna cut/turn and extend!
Finally gonna do something a bit different for the radius arms, I'm gonna do radius links! My main concerns are getting the bottom link up as high as possible which I think will be limited by the body mount. I also want to figure out what the best top down angle is. I want the links to attach to the beams close to the shock and spindle mount but don't want to limit turning radius to much.
Ok finally was able to make some progress on my beams. Had a guy bend up some C-shaped parts, best 140$ I have ever spent. Next up, I got some 1" by 3.5" 4140 plate on order to help kick out the bottom ball joint mount.
- IMG_8766.jpg (531.19 KiB) Viewed 2712 times
- IMG_8774.jpg (624.19 KiB) Viewed 2712 times
- IMG_8769.jpg (529.11 KiB) Viewed 2712 times
- Needles929
- Bronco Info: 95 Part Deux
Wow! You made that look easy... LOL
Nice Work!
Nice Work!
More info on steering wheel mod!
Thanks, Here are a couple pics of how I modified the 5 bolt -> 6 bolt adapter to run the wires out. The bracket is from the sock set up, i just ground it flat to sit between the two adapters. The second pic shows the connector coming out of the stock Ford slip ring (not shown), the only mod I made to the adapter is I had to drill a hole in the plate sits in the bottom of the adapter.
- steering .jpg (968.24 KiB) Viewed 2557 times
- slip ring.jpg (742.91 KiB) Viewed 2557 times
My buddy and I discussed that radius arm design. I like the idea of it but I found several epic fail pics of them. Running the two links like that takes a lot of the strength of the radius arm. I know people have done it successfully but I don't know if the performance gains (if any) are worth the reliability loss.
Not trying to deter you but I just thought its worth the discussion.
For sure, my thought are the links provide caster control which helps steering return/feel. Also because you steer very often improvements here would be a benefit. I do think links are not as strong in bending as a traditional radius arm setups so anything that hits the bottom link is a concern. I would love to see an pics of failures (always great to learn from broken parts). I'm running my links with a FK RSMX14T (1" shank, next size down from the 1 1/4" people normally run) on one end and a threaded bushing with 1-1/4" thread on the other side, bolt size is 5/8" on both ends with all 4130 bungs and tube with 1.75" .120" wall (I plan on heat treating). I figure these links can handle at least 45,000 lbf in tension/compression so I'm hoping if I don't crash in to a rock they won't break. I do plan on pushing the links up as much as I can I'm actually gonna trim the body mount.
Aslo I'm pretty sure the old Dave Ashely truck had this setup (check out this vintage video I found of it) https://www.youtube.com/watch?v=ushbhIx-ttA
Yes the Ashley truck had that setup.
This truck had them as well, but I'm not sure it was ever completed & run.
Small update, got my front end back from laser cut, managed to fit everything on a single 3' X 3' sheet of 3/16 4130, I'm also stoked on the lower ball joint mount just need to make a jig to locate it.
- 1.jpg (38.53 KiB) Viewed 2326 times
- 2.jpg (35.99 KiB) Viewed 2326 times
- 3.jpg (31.58 KiB) Viewed 2326 times
- Bobby Velazquez
- Bronco Info: 1992 Bronco XLT 302
It is coming great!
_______________________
CUCO Welding Shop Racing
Our Minds Are Always Racing
what is the taper on the reamer you are using?
