AOD with Len Tech Valvebody???
freechrisb@gmail.com
Bronco Info: 89 BrF150 on 33x17's no lift. Stroked and built 302, with Mustang electronics
Post by freechrisb@gmail.com »
Thinking about a Len Tech AOD Street Terminator valvebody -with the elec. overdrive switch; anyone have one, do U like it? It would b going behind a stroker 347. 33s 4:56 gears; that gets driven almost everyday.
Re: AOD with Len Tech Valvebody???
Sounds like a pretty good plan to me. Rob had a well-used, stock AOD in his that survived quite a while with a modified valve body (not sure if it was LenTech).
CrazyBRONCOguy
Bronco Info: 1992 and a 1978
Post by CrazyBRONCOguy »
Is this with the constant pressure modification as to make it so if the TV cable failed its a none issue?
'92 Eddie Bauer- C6 Swap, 9" Swap, Roller 357W, AFR 165's, MAF, SCT Tuned, 4.10's
'78 Custom- 4" Deaver Lift, Mild 460, 8 Point Cage, 4.10's
Bondobob
Post by Bondobob »
Dan Gilsdorf built it. He is Silver Fox transmission and does lots of high HP AOD stuff. The valve body was a great upgrade.
http://silverfoxtrans.com/silverfoxtrans.com/Home.html
Elwood Blues -1980
