92 XLT BUILD
- THEJESUS
- Bronco Info: WHITE 1992 BRONCO XLT w/ 4" LIFT ON 35" TOYO OPEN COUNTRY'S
92 XLT BUILD
Gotcha! I thought that's what you were talking about I just wanted to make sure. Ugh this is why you don't buy cars from Mexico haha jk I don't regret it just a pain at times.
How far from Murrieta are you?
92 XLT BUILD
These are the stock ones. One set has the built in sway bar bracket and the other is a 2 piece design with the swaybar bracket separate from the coil retainer. I have both designs and either will work. Let me know.
- THEJESUS
92 XLT BUILD
Awesome! If possible I would like the ones with out bracket since I'm not running the sway bar anymore anyway.
Are you far from Murrieta?
92 XLT BUILD
Sent you a message through tapatalk
- THEJESUS
92 XLT BUILD
finally got to wear my new GFB shirt and gunna take the bronco out for a drive it's been awhile!
Re: 92 XLT BUILD
Are the tee shit available again ?
- THEJESUS
92 XLT BUILD
Tcinu2 I believe it's Ollie that deals with it and he had about 2 or three left.
Might want to PM him and see what he has available.
- THEJESUS
92 XLT BUILD
Well here is difference between the stock spring retainer and the Mickey Mouse one they did in Mexico haha. On top of that here is the sketchy extended bolt they added on to it to make it all work... hahaha
- THEJESUS
92 XLT BUILD
Thanks to Travis for getting me the new bolts and spring retainers! Finally all done now time for an alignment
92 XLT BUILD
Glad to help does it look like the camber is better now?
- THEJESUS
92 XLT BUILD
Travis it does have less camber but it's still there. I'm hoping once I get the alignment they will be able to actually get it dialed in this time.
- THEJESUS
92 XLT BUILD
Everything is sitting nice now! After all the work it was worth it even had to save my buddy in his FJ. Was a pretty muddy situation and got stuck in a rut but no worries the bronco was there to save him
92 XLT BUILD
Sweet. Glad we could help out.
- THEJESUS
Re: 92 XLT BUILD
Its been awhile since i've actually done anything to the bronco. I finally had some time these past couple of weeks to get some work done
I made a box for bed area of the bronco..
also my dome lights werent working so I decided to get a rock light and wire it to a switch to have some interior lighting. It was a great idea because it is super bright!
- IMG_4019.JPG (70.24 KiB) Viewed 902 times
- IMG_4018.JPG (84.52 KiB) Viewed 902 times
- IMG_4015.JPG (70.93 KiB) Viewed 902 times
- Needles929
- Bronco Info: 95 Part Deux
- THEJESUS
Re: 92 XLT BUILD
Thanks! next is getting gas charged shocks to lift it up and setting up a little LED light for night. it works great with the seats folded down the box can support my weight no problem so I can lay an air mattress down and camp in the bronco
- Needles929
Re: 92 XLT BUILD
Post some more pics up when finished!! PleaseTHEJESUS wrote:Thanks! next is getting gas charged shocks to lift it up and setting up a little LED light for night. it works great with the seats folded down the box can support my weight no problem so I can lay an air mattress down and camp in the bronco
- THEJESUS
Re: 92 XLT BUILD
Finally got to take the bronco out to go camping. my fiance and I headed out to joshua tree we used the inside of our bean bag which lays out to a twin size bed for our mattress... making he box the same height as the seats folded down was perfect! we slept perfect! Here are a few pics of how our setup was
- IMG_4110.JPG (645.95 KiB) Viewed 822 times
- IMG_4097.JPG (235.98 KiB) Viewed 822 times
- IMG_4105.JPG (313.72 KiB) Viewed 822 times
- IMG_4106.JPG (259.67 KiB) Viewed 822 times
